Pietenpol-List: front seat shoulder harness attach
> RE: Pietenpol-List: front seat shoulder harness attach
et>Both the UK design (and Dan H.'s implementation, each featuring large turnbuckles or threaded mounts) and Santiago's design (with boltable straps) allow the builder to weld only part, if any, of the pieces, and otherwise slip in components under the plywood and cowling pieces, and around the instruments, then assemble in place.This can be an advantage.- If you weld and bolt up the harness assy. first, and then build all the rest, you can make it all one piece as welded.- But then the harness assy. a) is either in in your way as you run tubing, wires, cables, and mount instruments, put the ply pieces up, etc., or b) requires you to keep putting the mount in an out to see if things clear, and to get it out of the way.I am not saying this as artfully as I might, but perhaps you get what I mean.Tim in central TX-----Original Message----->From: Bill Church >Sent: Jun 10, 2009 2:38 PM>To: pietenpol-list(at)matronics.com>Subject: RE: Pietenpol-List: front seat shoulder harness attach>>>I've seen photos and drawings of the UK design (see>http://www.westcoastpiet.com/seatbelts.htm ), and I have not been able>to come up with a reasonable explanation as to why they need to have>those turnbuckle-type fittings in there. I can't see why a builder would>not be able to determine a fixed position and build the shoulderstrap>support rigidly, just like Ben Charvet has done. Perhaps it's because>the UK is much more restrictive towards homebuilt aircraft - EVERYTHING>has to be approved, so the drawings would allow for adjustment to suit>each particular aircraft. Ben's approach makes sense to me.>>Bill C.- >le, List Admin.________________________________________________________________________________Date: Thu, 11 Jun 2009 02:35:50 -0500 (GMT-05:00)
Re: Pietenpol-List: Clearance for aileron cables-- passenger harness
Original Posted By: "Tim Willis"
Thanks Tim. The photo didn't come thru but I see that Dan has sent one. It looks like what I'm looking for.ThanksGene----- Original Message -----
Tim, I spoke too soon. The photo did come thru, I just didn't scroll down far enough. Again, thank you.Gene----- Original Message -----
Re: Pietenpol-List: front seat shoulder harness attach
Dan, Just what I was looking for! Very well done. Gene ----- Original Message -----
Bill & Santiago, The UK design takes the cross brace cables off the top of the shoulder harnessattach, the turnbuckle-type fittings are how they adjust the cross brace cables.I made mine almost the same as Ben. After seeing Santiago's design, I wish I haddone it that way, very cool Santiago.Skip----- Original Message -----
Also check photos for Leon Stephan's Piet athttp://mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID=282On Jun 11, 2009, at 10:08 AM, Catdesigns wrote:> >> Take a look at Ty Daniels wheels on his Pietenpol. I believe he used > ATV tires and rims. Typically, the knobs are cut off and the tire > sanded smooth. Sounds like a lot of work but looks really good.>> http://www.westcoastpiet.com/new_page_54.htm>> I think there was a drawing of an adapter plate for ATV rims in one > of the old BPA newsletters. I will try to dig it out tonight and > scan it.>> Chris>> --------> Chris Tracy> Sacramento, CA> WestCoastPiet.com>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: RE: Pietenpol-List: front seat shoulder harness attachDate: Thu, 11 Jun 2009 11:38:56 -0400
Subject: Re: Pietenpol-List: front seat shoulder harness attach
REAL Wacos don't have shoulder harnesses. Stearman shoulder harnesses do not attach to the welded steel fuselage, the aluminum (or wood) seat is the attach point for the shoulder harness. The same thing for later Wacos. Because some Stearmans had wooden seats, you are back at square one.Gene ----- Original Message -----
Re: Pietenpol-List: Re: Pietenpol-List Digest: aileron cable leads
Don't forget, 3 maximum for fairleads.Clif"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery> Thanks Tim; Depending on how severe the turn in the cables has to be > I will either use a couple of extra pulleys or just fiarleads if the > change in direction is fairly small.> Jim________________________________________________________________________________Date: Fri, 12 Jun 2009 08:10:12 -0400 (GMT-04:00)
Re: Pietenpol-List: "Share a Ride" from Madison to Brodhead?
Subject: Re: Pietenpol-List: "Share a Ride" from Madison to Brodhead?Jim,We are staying at the Hampton Rockford and can providee transportation toand from Rockford on Saturday of that works for you.Please adviseJohn**************Shop Dell=99s full line of Laptops now starting at $349! =http:%2F%2Fad.doubleclick.net%2Fclk%3B215218036%3B37264217%3Bz)________________________________________________________________________________
> > Here is one way of doing it.> > > > Dan Helsper> > Poplar Grove, IL ________________________________________________________________________________Subject: Re: Pietenpol-List: front seat shoulder harness attachDate: Wed, 10 Jun 2009 07:21:04 -0400
> Ameet,>> The way I see it, if it did rotate the total movement would> be max. 1" (unless the bolt pulled out of the> longeron). After the first 20 degrees of turning, it would> come in contact with the rod end fittingwhich would> take some energy to twist. All in all I believe it would go> a long way on holding back the shoulders of the front seat> passenger in a crash.>> What stage are you at> with your build?> > > > Dan Helsper ________________________________________________________________________________
>>>Both the UK design (and Dan H.'s implementation, each featuring large turnbucklesor threaded mounts) and Santiago's design (with boltable straps) allow thebuilder to weld only part, if any, of the pieces, and otherwise slip in componentsunder the plywood and cowling pieces, and around the instruments, then assemblein place. This can be an advantage. If you weld and bolt up the harnessassy. first, and then build all the rest, you can make it all one piece aswelded. But then the harness assy. a) is either in in your way as you run tubing,wires, cables, and mount instruments, put the ply pieces up, etc., or b) requiresyou to keep putting the mount in an out to see if things clear, and toget it out of the way. I am not saying this as artfully as I might, but perhapsyou get what I mean.// Tim in central TX>>-----Original Message----->>From: Bill Church >>Sent: Jun 10, 2009 2:38 PM>>To: pietenpol-list(at)matronics.com>>Subject: RE: Pietenpol-List: front seat shoulder harness attach>>>>>>I've seen photos and drawings of the UK design (see http://www.westcoastpiet.com/seatbelts.htm ), and I have not been able>>to come up with a reasonable explanation as to why they need to have those turnbuckle-typefittings in there. I can't see why a builder would not be able todetermine a fixed position and build the shoulderstrap support rigidly, justlike Ben Charvet has done. Perhaps it's because the UK is much more restrictivetowards homebuilt aircraft - EVERYTHING has to be approved, so the drawingswould allow for adjustment to suit each particular aircraft. Ben's approach makessense to me. // Bill C. ________________________________________________________________________________Date: Thu, 11 Jun 2009 08:40:03 -0400
> >> timothywillis(at)earthlink.net>> >> >Both the UK design (and Dan H.'s implementation, each featuring large> turnbuckles or threaded mounts) and Santiago's design (with boltable straps)> allow the builder to weld only part, if any, of the pieces, and otherwise> slip in components under the plywood and cowling pieces, and around the> instruments, then assemble in place. This can be an advantage. If you weld> and bolt up the harness assy. first, and then build all the rest, you can> make it all one piece as welded. But then the harness assy. a) is either in> in your way as you run tubing, wires, cables, and mount instruments, put the> ply pieces up, etc., or b) requires you to keep putting the mount in an out> to see if things clear, and to get it out of the way. I am not saying this> as artfully as I might, but perhaps you get what I mean.// Tim in central> TX> >> >-----Original Message-----> >>From: Bill Church > >>Sent: Jun 10, 2009 2:38 PM> >>To: pietenpol-list(at)matronics.com> >>Subject: RE: Pietenpol-List: front seat shoulder harness attach> >>> >>> >>I've seen photos and drawings of the UK design (see> http://www.westcoastpiet.com/seatbelts.htm ), and I have not been able> >>to come up with a reasonable explanation as to why they need to have> those turnbuckle-type fittings in there. I can't see why a builder would not> be able to determine a fixed position and build the shoulderstrap support> rigidly, just like Ben Charvet has done. Perhaps it's because the UK is much> more restrictive towards homebuilt aircraft - EVERYTHING has to be approved,> so the drawings would allow for adjustment to suit each particular aircraft.> Ben's approach makes sense to me. // Bill C.>>-- Rick HollandCastle Rock, Colorado________________________________________________________________________________
>> > >Both the UK design (and Dan H.'s implementation, each featuring large turnbuckles or threaded mounts) and Santiago's design (with boltable straps) allow the builder to weld only part, if any, of the pieces, and otherwise slip in components under the plywood and cowling pieces, and around the instruments, then assemble in place. This can be an advantage. If you weld and bolt up the harness assy. first, and then build all the rest, you can make it all one piece as welded. But then the harness assy. a) is either in in your way as you run tubing, wires, cables, and mount instruments, put the ply pieces up, etc., or b) requires you to keep putting the mount in an out to see if things clear, and to get it out of the way. I am not saying this as artfully as I might, but perhaps you get what I mean.// Tim in central TX > >-----Original Message----- >>From: Bill Church > >>Sent: Jun 10, 2009 2:38 PM >>To: pietenpol-list(at)matronics.com >>Subject: RE: Pietenpol-List: front seat shoulder harness attach >> >> >>I've seen photos and drawings of the UK design (see http://www.westcoastpiet.com/seatbelts.htm ), and I have not been able >>to come up with a reasonable explanation as to why they need to have those turnbuckle-type fittings in there. I can't see why a builder would not be able to determine a fixed position and build the shoulderstrap support rigidly, just like Ben Charvet has done. Perhaps it's because the UK is much more restrictive towards homebuilt aircraft - EVERYTHING has to be approved, so the drawings would allow for adjustment to suit each particular aircraft. Ben's approach makes sense to me. // Bill C. ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Coloradohttp://www.matronics.com/Navigator?Pietenpol-L ... __________
