Pietenpol-List: Doug Fir as a substitute
Re: Pietenpol-List: Straight Axle gear questions
Original Posted By:=0A Michael Groah
Mike,=0A=0APlease see the attached. As you might see, I have elongated the "sheath" tube on my "axle locator" tube system into an oval shape. This is to allow a "rocking" motion on the gear, without putting an undo strain on the tube that is welded onto the axle. Please note I have not flown with this set-up. I unashamedly copied it from Simon McCormack from "down under" www.westcoastpiet.com. They look at things from a "different" perspective there, and many times have some superb ideas. Also, have you looked at Chris Tracey's straight axle gear fabrication instructions on the westcoastpiet site?=0A=0ADan Helsper=0APoplar Grove, IL=0A=0A=0A-----Original Message-----
Mike,Please see the attached. As you might see, I have elongated the "sheath" tube on my "axle locator" tube system into an oval shape. This is to allow a "rocking" motion on the gear, without putting an undo strain on the tube that is welded onto the axle. Please note I have not flown with this set-up. I unashamedly copied it from Simon McCormack from "down under" www.westcoastpiet.com. They look at things from a "different" perspective there, and many times have some superb ideas. Also, have you looked at Chris Tracey's straight axle gear fabrication instructions on the westcoastpiet site?Dan HelsperPoplar Grove, IL-----Original Message-----
Thank you for the help, both Jack and Dan.- Yes Dan I've read the gear construction write up that Chris did on westcoastpiet.com.- I chose to do mine differently (right side up), but still got the job done.- Thanks for the tips.- I'll get to work on the axle part soon.- Hopefully you can see the attached pic of what I have done thus far.- Mike GroahTulare CA--- On Mon, 6/15/09, helspersew(at)aol.com wrote:
Subject: Pietenpol-List: (no subject)Gary,I think you're really going to enjoy working with poplar and the price is always good.John**************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! eExcfooterNO62)________________________________________________________________________________Date: Tue, 16 Jun 2009 10:13:09 -0700Subject: Pietenpol-List: Doug Fir as a substitute
Re: Pietenpol-List: Doug Fir as a substitute
MarkI don't weight in very often, but I wanted to give my thoughts on this subject.I have a rare condition which my wife coined chronic tightassitis, with complications of overthinkitis. what this means is that I have looked over Doug fir in detail.I even laid out the numbers in a spreadsheet, and modeled the parts in Pro Engineer to check size reductions.what I discovered is that you can reduce the longerons by about a 16th of an inch if memory serves me and still be above the Stats and strengths of spruce while at the same time reducing the weight and offsetting some of the weight penalty. with that said the only number of Douglas fir that is less than Spruce is the Modulus of Elasticity (again if memory serves) and unless you plan on fatigue testing your piet, with aerobatics that number should never come into play, if you have a tendency to smack into hard things remember that Doug fir won't bend as far as spruce before it cracks. My ribs are all out of Doug Fir that is 12-14 growth rings per inch with a runout of less than 1 inch in 60, cut from a 12 foot 4x4 purchased at Menards for 12.95 I believe.Just my thoughts,JakeMark Roberts Sent by: owner-pietenpol-list-server(at)matronics.com06/16/2009 12:13 PMPlease respond topietenpol-list(at)matronics.comTopietenpol-list(at)matronics.comccSubjectPietenpol-List: Doug Fir as a substituteFirst, I would like to thank everyone for the patience you've shownwith my deliberations over the choice of wood or steel for the fuse. Irealize after looking at my posts that some of it might have been overthinking the issue, but if I am spending 4 years (I hope less) onbuilding something, I want to make sure I am happy with the results.Light = better for me
)However, looking at Doug Fir as an alternative to spruce... I amre-reading the EAA book on wood, and it struck me as funny that thesecond article in the book was about using Fir as a substitute forspruce. One of the next articles in the book was NOT to use anythingbut spruce for critical members such as Fuse longerons.Now, some reason need to be applied here, as everyone has a few basicthings in common: Body orifices and opinions (phrase cleaned up herefor general consumption...). I get that one guy says never use fir andanother says it's OK. The funny thing is, is both seemed to haveimpressive credentials. The one praising fir was a Dr. of aeronauticsand involved in sailplanes and the other was Mr. Evans of Volksplanefame. He said after reading about compression fractures in wood, thathe went back to recommending only spruce for structural members of theplane. Well (sigh).So, I am thinking, weight not withstanding (remember all of my otherposts wringing my hands about steel over wood??), what would be theequivalent size in fir to equal the same strength in spruce? Is therea rule of thumb? For instance, if I were to order from ACS or Wicks 1"x 1" capstrip spruce for the fuse construction, would the equivalentstrength size be say, 3/4" square? What could the fir be pared down toto equal the strength component of the spruce.Has anyone ever seen a comparison such as this?The first mentioned author said 'nuts' to the changing of sizes forthis type of substitution, and said just use the regular size calledfor and get over the weight difference. I am re-drawing / modeling theplane in stages in Sketch up 7 to determine all of the little thingsI'll encounter in the real build (a way of scratching the itch tillall the money is there...) and I could work out the inconsistencieswith the plans size changes then. I'm going to have to do this anywayas my height will warrant the deepening of the fuse a couple of inchesfor my long frame.Thanks for the feedback. I hope the posts don't seem like idle'excitement' chatter, as I am trying to wrap my head around thedetails before the build.(As an aside, the more I am reading, the more I am understanding thisis a normal phenomenon amongst homebuilders of the first go 'round. Ijust feel excessive in the ponderings. Job? What job.... I'm at 5000on a nice summer evening looking down on wafts of smoke billowing offof an agriculture burn, and seeing the lights pop on in little housesas I set up for final...
)Mark________________________________________________________________________This email has been scanned for SPAM content and Viruses by the MessageLabs Email Security System.________________________________________________________________________________________________________________________________________________________
RE: Pietenpol-List: Doug Fir as a substitute
Subject: Re: Pietenpol-List: Had a great time in your backyardIn the pleasant weather of Oklahoma I got a chance to meet with Mark at his Hangar at Grundys Airport. he's got a great shop, not to mention a more then ample supply of beverage on hand. We had some burgers and brew, talked abunch of Piet and attended the EAA chapter 10 meeting on the field. I had a great time enjoyed every bit of it met his family enjoyed every bit of it and you missed out, ha ha,hahahaJohn**************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! eExcfooterNO62)________________________________________________________________________________Subject: RE: Pietenpol-List: Doug Fir as a substituteDate: Tue, 16 Jun 2009 15:18:20 -0400
Subject: RE: Pietenpol-List: Doug Fir as a substituteThat list reminds me you don't hear of anyone making a plane of Pine and not toomany of Poplar even though those are the ones most commonly available. I wonderwhat the weight penalty would be using pine and compensating for the strength?Anyone ever heard of someone making a plane from Pine?Rodney---- Gary Boothe wrote: > Mark,> > Just a reminder about this page from AC41.13. It is void of personal> feelings and preferences. (hope it is attached OK)> > Gary Boothe> Cool, Ca.> Pietenpol> WW Corvair Conversion> Tail done, Fuselage on gear> (13 ribs down.)> > -----Original Message-----
Mark,Just a reminder about this page from AC41.13. It is void of personalfeelings and preferences. (hope it is attached OK)Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)-----Original Message-----
I am doing it in poplar as are others. As far as a rarity I am not too certainI agree with that part of your assessment. John Sent from my Verizon Wireless BlackBerry-----Original Message-----
Re: Pietenpol-List: Re: Had a great time in your backyard
Original Posted By: Mark Chunard
MarkThanks again. Next thing you'll have to do is to get a copy of TGWP and watch ituntil you can quote lines. "It has been very nice to have met you Mr Brown"At any rate, except for seeing Markles project progress on occasion Jim and I shouldvisit you when ever possible. John------Original Message------
RE: Pietenpol-List: cowling paint
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-li
May also help in future NTSB investigations=C2-
Original Posted By: "K5YAC"
Hello all,Did you guys paint the inside of your cowling or leave it bare?Douwe________________________________________________________________________________Subject: Pietenpol-List: Re: Had a great time in your backyard
That sounds like rumor to me... I would have a hard time believing the Mini-Max was ever kitted in pine.Might want to do some digging before I believe that.I have a Mini-Max fin kit, and it is definitely not pine. It's a new kit (2008).Wayne Bressler Jr.Taildraggers, Inc.taildraggersinc.comSent from my iPhoneOn Jun 16, 2009, at 9:33 PM, Owen Davies wrote:> >>>> Last I knew, the MiniMax ultralights were kitted in pine. Don't know > of any heavier aircraft, but I'd be surprised if they weren't > reasonably common.>> Owen>>________________________________________________________________________________
I've got a copy of TGWP, I just need to watch it several more times. As for you and Jim... there is a frosty mug waiting whenever you feel like stoppingby.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 16 Jun 2009 20:33:26 -0700 (PDT)
Re: Pietenpol-List: cowling paint
Subject: Re: Pietenpol-List: Doug Fir as a substitute
Go here and scroll down. There's a chart of wood strengths.http://clifdawson.ca/Tools_and_Tips.html> Mark,> > Just a reminder about this page from AC41.13. It is void of personal> feelings and preferences. (hope it is attached OK)> > Gary Boothe________________________________________________________________________________Date: Wed, 17 Jun 2009 05:43:40 -0400
Painted the inside white. Makes it very easy to peek inside and spot leaks.Gene----- Original Message -----
The insides of all the cowlings on 41CC were left in naturalaluminum. I sort of wish that the cockpit cowlings were atleast primed inside because they are visible. However, Corkyhad the wonderful presence of mind to have everyone who helpedhim on the airplane sign their names inside the engine top cowlingusing a black marker. Since I've owned the airplane, I've hadseveral others add their names inside the cowling... like SalHernandez, welder extraordinaire who did all of the landing gearand cabane strut repairs. I need to have engine guru Jeff Scottsign it, and tech counselor Norris Warner, and sheet metalmaestro Ed Talamantez, and Charlie, and... and... so many more!The inside of that cowling will carry a story with it for along time.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: RE: Pietenpol-List: Doug Fir as a substituteDate: Wed, 17 Jun 2009 08:15:28 -0400
May also help in future NTSB investigations. _____
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________________________________________________________________________________Date: Wed, 17 Jun 2009 16:42:30 -0400 (EDT)
Re: Pietenpol-List: layout notes-- "wingtip" thataway-->
Original Posted By:> Douwe Blumberg
DouweI engine turned the inside & outside.Dale> [Original Message]
My public apologies to Owen for doubting him. I did some searching on the ETLB forums where the Mini-Max guys hang out, and it turns out that those kits have been using some mix of spruce, douglas fir, and "northern" white pine for a number of years. I couldn't find difinitive answers on what was pine, and what was spruce, though.I guess I'll have to dig my fin kit out and have a closer look!I need to check the wood guides to compare the specs on the white pine.Sorry to stray off topic.Wayne Bressler Jr.Taildraggers, Inc.taildraggersinc.com>>>>________________________________________________________________________________
It's not a square cushion is it??Clif"Cogito cogitas, ergo cogito sum."("I think I think, therefore I think I am.") Subject: Re: Pietenpol-List: layout notes-- "wingtip" thataway--> I myself put one of those arrows on the pilot's seat, just so I remember which way I will be going. Dan Helsper________________________________________________________________________________Date: Wed, 17 Jun 2009 23:12:33 -0400
Pietenpol-List: Re: Pietenpols on the big screen
I like the original trailer better, but I am still looking forward to seeing thefilm.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 17 Jun 2009 20:26:36 -0700 (PDT)
Re: RE: Pietenpol-List: cowling paint
Original Posted By: "Jim"
Dale used a 1" piece of 3M Scotchbrite pad attached to a wooden dowel in the drillpress. The 1" circles are overlapped 1/4". I don't know how long it took but Dale reports the job as being "tedious".Greg C.----- Original Message -----
The question of weight and Doug fir comes up often so I searched the archives to see what Steve Eldrige had to say about his. There is a lot of information in the archives that people should look at more often.Back in 2000, Steve said"The above statement is simply exaggerated. I built my piet exclusively withdoug fir. Flying weight is 626 pounds (short fuselage, A-65). Total cost for the fir was less than$600. Spars, longerons, the whole works. 108 brd feet at about $5.75 perboard ft. I estimate my increase in weight over spruce is less than 15lbs,if that. Cost was about a quarter that of spruce.For what it is (or isn't) worth,Steve E."ChrisSacramento, CAWestCoastPiet.com----- Original Message -----
Original Posted By:> ----- Original Message ----- "Mark Roberts"
Mark,Save yourself the anguish of loosing a few pounds, tell your wife to and if you phrase it right "when I add mywife and fuel..." you might only have to add fuel ;-)Hope this helps.JakeMark Roberts Sent by: owner-pietenpol-list-server(at)matronics.com06/19/2009 10:21 AMPlease respond topietenpol-list(at)matronics.comTopietenpol-list(at)matronics.comccSubjectRe: Pietenpol-List: Doug Fir as a substituteThanks Chris. I ned to figure out how to search the archives to seewhat discussions have "been there, done that."Thanks for the post, as I am leaning that way (today) in my decisionprocess. I met with a friend last night that builds a lot of stuffwith wood, and he'll help me pick the stuff out if I ask him. I needto be right at 650 lbs or so empty to be comfortable when I add mywife and fuel... If I lose a few pounds too.
)MarkOn Fri, Jun 19, 2009 at 6:56 AM, wrote:>> The question of weight and Doug fir comes up often so I searched the> archives to see what Steve Eldrige had to say about his. There is a lot of> information in the archives that people should look at more often.>> Back in 2000, Steve said> "The above statement is simply exaggerated. I built my piet exclusively> with> doug fir. Flying weight is 626 pounds (short fuselage, A-65). Total cost> for the fir was less than> $600. Spars, longerons, the whole works. 108 brd feet at about $5.75 per> board ft. I estimate my increase in weight over spruce is less than 15lbs,> if that. Cost was about a quarter that of spruce.>> For what it is (or isn't) worth,>> Steve E.">> Chris> Sacramento, CA> WestCoastPiet.com>>
Original Posted By: jb.spiegel(at)us.schneider-electric.com
No inspection rings on the top surfaces anywhere on 41CC...all are on the shady side.Oscar ZunigaAir Camper NX41CCGetting engine swap to A75San Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: Re: Pietenpol-List: Doug Fir as a substitute
Original Posted By:> ----- Original Message ----- "Mark Roberts" Sent by: owner-pietenpol-list-server(at)matronics.com06/19/2009 10:52 AMPlease respond topietenpol-list(at)matronics.comTopietenpol-list(at)matronics.comccSubjectRe: Pietenpol-List: Doug Fir as a substituteThanks Jake! My wife is upstairs and just asked "What are you laughing at...?" and I had to say "Nuthin' Honey!"We just watched a 'Forensic File' episode on TRU tv last night where a nurse killed her husband while he slept with some kind of tranquilizer for insurance money... I'm not pushing my luck! I now have an educated wife!!MarkOn Fri, Jun 19, 2009 at 8:39 AM, wrote:Mark, Save yourself the anguish of loosing a few pounds, tell your wife to and if you phrase it right "when I add mywife and fuel..." you might only have to add fuel
Hope this helps. Jake Mark Roberts Sent by: owner-pietenpol-list-server(at)matronics.com 06/19/2009 10:21 AM Please respond topietenpol-list(at)matronics.comTopietenpol-list(at)matronics.com ccSubjectRe: Pietenpol-List: Doug Fir as a substituteThanks Chris. I ned to figure out how to search the archives to seewhat discussions have "been there, done that."Thanks for the post, as I am leaning that way (today) in my decisionprocess. I met with a friend last night that builds a lot of stuffwith wood, and he'll help me pick the stuff out if I ask him. I needto be right at 650 lbs or so empty to be comfortable when I add mywife and fuel... If I lose a few pounds too.
Subject: Pietenpol-List: Jim Markle's stunt double flies the F-16 at the ParisAirshowThe guy doing the announcing here is a Lockheed-Martin Chief Airshow Test Pilot (talk about a dream job) and hasa resemblance to Jim Markle.It does my heart good to know that old guys like us can still fly hot jets like that in airshow demonstrations. (of coursewe'll never get the opportunity but we can always do smoke jobs at Brodhead or formation with a few other Peterpullers.http://www.aviationweek.com/aw/video/?f ... ______Date: Fri, 19 Jun 2009 10:07:04 -0700Subject: Re: Pietenpol-List: Doug Fir as a substitute
Re: Pietenpol-List: Jim Markle's stunt double flies the F-16 at the Paris
Subject: Re: Pietenpol-List: Jim Markle's stunt double flies the F-16 at the ParisAir...The only way to tell the difference is Markle doesn't fly jets! Now if it were the Piet well then it could be Markle in the split S maneuver.John**************Dell Inspiron 15: Now starting at $349 net%2Fclk%3B215748553%3B38126199%3Bs)________________________________________________________________________________Date: Fri, 19 Jun 2009 14:00:42 -0700 (PDT)
Original Posted By: Jim
> Subject: Pietenpol-List: cowling paint>>> Hello all,>> Did you guys paint the inside of your cowling or leave it bare?>> Douwe>>________________________________________________________________________________Date: Wed, 17 Jun 2009 21:29:22 +0000 (GMT)
Pietenpol-List: Pietenpols on the big screen
Original Posted By: "Baldeagle"
> Subject: Pietenpol-List: cowling paint>>> Hello all,>> Did you guys paint the inside of your cowling or leave it bare?>> Douwe>>________________________________________________________________________________Subject: Pietenpol-List: Pietenpols on the big screen
Original Posted By: "Rob Stapleton"
>> Subject: Pietenpol-List: cowling paint>>> >>>> Hello all,>>>> Did you guys paint the inside of your cowling or leave it bare?>>>> Douwe>>>>>>>>> ________________________________________________________________________________
