Pietenpol-List: 8409 Corvair Crankshaft
Perhaps this should be in the Corvair engine section, but there is much more activityin the Piet section, and plenty of Corvair gurus. Simple question... does this look like and 8409 crankshaft to you guys? This numberis stamped between the 1st and 2nd connecting rod journals. The "84" portionas perfectly clear, but the other two digits could be an two round characters...difficult to make out. Could it be anything else? I mean, were thereother series of numbers they stamped that may be similar, or is it a prettysafe bet that "8 4 X X" is 8409.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/8409 ... __________
Re: Pietenpol-List: 8409 Corvair Crankshaft
That's an 8409 crank, Mark. To me, the '09' is faint, but it's there. Either way, the only other codes that would be stamped are 5607, and I think 7293. So you have the right one. Congrats!RyanSent from my iPhoneOn Jun 21, 2009, at 3:32 PM, "K5YAC" wrote:>> Perhaps this should be in the Corvair engine section, but there is > much more activity in the Piet section, and plenty of Corvair gurus.>> Simple question... does this look like and 8409 crankshaft to you > guys? This number is stamped between the 1st and 2nd connecting rod > journals. The "84" portion as perfectly clear, but the other two > digits could be an two round characters... difficult to make out. > Could it be anything else? I mean, were there other series of > numbers they stamped that may be similar, or is it a pretty safe bet > that "8 4 X X" is 8409.>> --------> Mark - working on wings>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 389#249389>>> Attachments:>> http://forums.matronics.com//files/8409 ... ______Date: Sun, 21 Jun 2009 15:57:25 -0600Subject: Re: Pietenpol-List: 8409 Corvair Crankshaft
Pietenpol-List: Re: 8409 Corvair Crankshaft
Original Posted By: bmccraw(at)cogeco.ca
Thanks fellers... so far, this disassembly is looking great.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Pfeifer Sport plans
Original Posted By: "Michael Silvius"
> Darrel: Can you send a copy of the Pfeifer plans to Canada? Tell me how muchand I'll send it.ThanksBill McCraw>> Hey Darrel>> Just wanted to make sure you received my payment.>> Please advise>> Thanks>> John Recine>>> > **************A Good Credit Score is 700 or Above. See yours in just 2 easy> steps!> JunestepsfooterNO62)>________________________________________________________________________________
Re: Pietenpol-List: A75 swap on 41CC
Subject: Re: Pietenpol-List: A75 swap on 41CCBeautiful. I'm as proud as you.Corky**************Download the AOL Classifieds Toolbar for local deals at your fingertips. (http://toolbar.aol.com/aolclassifieds/d ... wn00000004)________________________________________________________________________________
Original Posted By: "K5YAC"
Sure looks like it to me. The other way to tell, if your crank wont turnenough to see the number is by looking for the case clearance cut out wherethe connecting rod bolts go past the side of the case right by the cylinderbore. Stick the tip of your finger in there and feel for the swath of thecase that has been machined out to clearance the travel of the connectingrodbolt. If it does not have it has the old short throw crank. Not the endof the world but the case made for the 8409 is the desirable one.To see what you are looking for on the case go to Pat Panzera' page at:http://www.experimental-aviation.com/Co ... .htmlfirst pix is an older case for the short throw crankthe third pix is what you are looking for.As you notice Pat shows us the way to make an old case fit an 8409 crank.So if some one gives you an old case I would not turn it down either. Awhile back I was the fortunate recipient of just such a gift via ourcomrade at arms Alan Lyscars. Some day I will try Pat Panzeras conversiontrick just for yuks.Michael----- Original Message -----
More details on the subject of Corvair engine identification from PatPanzera's page at:http://www.angelfire.com/ca4/CorvAIRCRA ... __________
