Pietenpol-List: corvair mounts
well I'm in the process of trying to get the engine back on my project I got fromDJ. it was funny when I read the BPA newsletter and found that I had it finishedand flying with a strange N number. I wish! anyway-I have the polyurethanemounts that it came with and the 3/8" bolts but I surely want to make somewear sleeves to go over the bolts to take up the space between the bolt and thecase. it measures about .550" I.D. has anybody found anything really toughlike a Teflon plastic sleeve in the right diameters? I know I can find some inlarger diameters that are used to insulate bolts on large Pipe flanges.if necessaryI can cut them down and roll them tighter but I'd rather it was solid.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: corvair mounts
RaymndI think we bought the correct size from Aircraft Spruce. I'll check it inthe next couple of days. We might have a little left over that I could mailto you, but let me check first. (it only takes a couple of inches for the 4bolts)Barry Davis -----Original Message-----
Pietenpol-List: Re: corvair mounts
Original Posted By: "Lagowski Morrow"
Well I was at the hardware store and found some 1/2" O.D. Polyethylene tubing thatseems tough. I think I may try that on my bolts where they pass through thecase holes.I will make a mental note to keep watch on them and see if I cansee any wear.for sure it would be a good item to inspect at annuals.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: corvair mounts
Jim I'm just starting a piet project and could make good use of the material.i sent an email also.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 28 Jun 2009 18:48:24 -0500Subject: Re: Pietenpol-List: Re: corvair mounts
Original Posted By:> "skellytown flyer"
Teflon would be a good choice too, but you'd probably have to make them yourself from round stock. We used to use it to make parts & equipment for the oceanographic work I did. Fairly rugged, completely chemical resistant, and easy to work. It also won't contaminate sea water samples, but that would only matter to Corky, I suppose :) Would be kind of pricey, I imagine.Kip GardnerOn Jun 29, 2009, at 8:39 PM, Stu Brown wrote:> >> I believe you will find polyethylene unsuitable for bushing > material PE will cold flow and is not much good above 160F. > Polyurethane would be a more suitable choice.>> Stu Brown>>> Subject: Pietenpol-List: Re: corvair mounts
RE: Pietenpol-List: Re: corvair mounts
Hi Ryan,I did not want to delete this from my inbox without thanking you. Obviously,I got a little sidetracked with Brodhead and all, but when I got home I didsome real searching. Using the key words in Mark's description, I finallyfound these at Summit Racing, online, and had the grommets within 2 days! Iam now ready to get the engine on its mount after I first finish up thebrakes this weekend.Hopefully all is going well for you and Jess in moving your project to thehanger/barn. I very much enjoyed meeting both of you.Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
Subject: Re: Pietenpol-List: and don't forget those Canadian's eh ?Actually because of the exchange rate it is only the 86.4 year anniversary of flight in Canada.I'm here all week folks. Try the veal and don't forget to tip your waiter."Is that all you plan to do for the rest of your life? Just cash for rides?"Do not archve.John HofmannVice-President=2C Information TechnologyThe Rees Group=2C Inc.2810 Crossroads Drive=2C Ste 3800Madison=2C WI 53718Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Jun 24=2C 2009=2C at 2:22 PM=2C Cuy=2C Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote:And not to leave out the first 100th year anniversary of flight in Canada EAA is havingsome special doings at Oshkosh to celebrate that event that took place in 1909. Bill Church isour resident Pietenpol poster boy and I think Harvey Rule too. Were you there for that firstflight Harve ?http://www.eaa.org/news/2009/2009-02-23_canada.asp href="http://www.matronics.com/Navigator?Pietenpol-List" style="color: blue=3B text-decoration: underline=3B ">http://www.matronics.com/Navigator?Pietenpol-List blue=3B text-decoration: underline=3B ">http://forums.matronics.com style="color: blue=3B text-decoration: underline=3B ">http://www.matronics.com/contribution ========= )=AD=E6=DF=A2{l=8B7=B6r=89h=AFM4=D3M=1Fi=C7=9C=A2=EAz=B9=DE=C1=CA.=AE'=ABN=17=8F=89=EB^=9E=9A%.+-=12f=A2=94Z+=BAe=2Cz=D8^1=ABk=A2x=9C=B0=B8=AC=B4W=9A=B6=EA=DE=B0=D6=AF=8A=06=AD=A2=BBhn=BA0=B1=EBazf=A7=C8=B8=AC=B6=EBb'+bz=CB.r=16=AC.+-R=7F=D2=B9=BB=1C=AE*m=8A=89=C0=AD=C8b=BD=E4=9Ej=B7!=0E=8C''=86=9D=EC6=B2=06=BA0=B1=E0=A1j=D1@@=F8h=B6=8B!j=B7=9A=9D=D9=AEr=19=AEr=19=A8=AD=E6=A1=AD=E7=E1=B6=DA=7F=FF 0=99=ABk=A2x=9C=B1=CA&=FC=D6=AF=8A=06=AD=A2=B3z=D7=A7=89K=8A=CBa=B6=DA=7F=FF 0=99=ABk=A2x=9C=B1=CA&=FC=D6=AF=8A=06=AD=A2=B3z=D7=A7=89K=8A=CB=7Fh=C0=13D=E3H %=84=04S=91P=C4=92jg =AD=E6=ADr=89=EDz{Z'=CA=1A=BD=A8=A5i=B9^=BE&=AD=85=E5=9ElZ+=BAk=1A=86=B7=9F=86=DBi=FF=F7=E8=AE=E9=AC=99=ABk=A2x=9C=B1=CA&=86=DBi=FF=F7=E8=AE=E9=AC=99=ABk=A2x=9C=B1=CA&=FD=A2=B2=D0=A8=9E=DAn=EBb=A2u=9Em(=ADy8Z=9EL=A8=B9=FA+=CA=8B=AB=81=E9=DE=AE=8B=AC=B2=EAi=A2=BBLj=DBC=AD=A9ex=B8=AC=B4=07f=8Av=A1=AD=E7=E1=B6=DA=7F=FF 0=99=ABk=A2x=9C=B1=CA&=FD=CA'=B6=B8=9B=BA=D8=A8=9E=1Bm=A7=FF=F0=C3 =9A=B6=BA'=89=CB=1C=A2o=DC=A2{k=89=BB=AD=8A=89=FFk=F6=FF~=89=ED=FE=9A=DE=FD=BA=1D=CB=F8m=9A_________________________________________________________________Create a cool=2C new character for your Windows Live=99 Messenger. http://go.microsoft.com/?linkid=9656621 ... ___Subject: Pietenpol-List: corvair mounts
