Original Posted By: H RULE
Jim;I worried about seeing the instruments. I need "cheaters" orbifocals to see things up close and the restrictions on myairman medical say I need to have corrective lenses when Ifly. I wear contact lenses for distant vision but for nearvision I always carry reading glasses with me when I fly butI've never had occasion to take them out because I can alwayssee what needs to be seen without them. I have NO digitaldisplays or instruments but if I did, I might need those readersto see some of the text. With analog gauges, a quick glanceshows me what I need to know without hesitating or guessing.Can you tell that I'm a "steam gauge" type of guy? ;o)When I fly X-C, I fly with a kneeboard and a folded sectional,with my route of flight laid out and highlighted. I have nothad any problem seeing my next checkpoint on the chart, downon my knee in the cockpit.I'm in a little bit of trouble if I have to read the airportinfo or radio frequencies in tiny print on the chart or if Ineed to read the tenths and hundredths of tach time in the littlewindow on the tach but, oddly enough, I have no trouble dialingin the altimeter reading (barometric pressure) in the Kollsmanwindow. I can read every gauge on the panel and everything inthe panel of 41CC is a dial instrument, set in the stockconfiguration per plans, and with the green-yellow-red rangesmarked on the gauges. Even a child can tell if everything isin the green and that's all you need to see in flight. Whenyou're flying a Piet, the first one or two digits on the rightof any gauge readout don't interest you anyway ;o)Don't over-think this stuff. If you sit in the shop and worryabout what-ifs, you'll worry yourself silly and you'll neverfinish the airplane. I am also a scuba diver and I tend to usethe same philosophy in my dive gear... simple and lean. Ihave to laugh as I watch gadget freaks waddle off with thingshanging from clips and lanyards all over their suits and BCs,and with plotters and aids and gizmos on every D-ring and strap...and they get so consumed with what might happen that they neverenjoy the dive. Me, I fly the airplane and just check thegauges to confirm what the airplane and engine are telling me.The Piet talks real pretty and sweet, and only an occasionalglance at the gauges is needed to confirm what the airplanetells you.I never thought I'd say this since I'm an engineer and adetailer, CAD designer and an experimenter, but the Piet designis well proven for over 80 years now, so I'm going to join thechorus and here goes: "build it to the plans and you'll dojust fine!"Any changes you want to make, you can make after you fly offthose test hours or after you start your NEXT Piet and areenjoying flying your first one!!!! Yes, there are repeatoffenders on this list... I already have a set of landing gearand a Corvair engine and prop for my next Air Camper.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Tue, 30 Jun 2009 20:02:45 -0700 (PDT)
Pietenpol-List: seeing the instruments
Re: Pietenpol-List: seeing the instruments
Original Posted By: Mike Tunnicliffe
Original Posted By: Jim
Re: Pietenpol-List: Plywoods
This cable holds the brake from rotating.I'm going to use this idea. ----- Original Message -----
Re: Pietenpol-List:Preventing axle rotation Was:Plywoods
Check out how John Dilatush prevented axle rotation on Mountain Piet.http://www.westcoastpiet.com/images/Joh ... C00049.JPG ----- Original Message -----
Subject: Re: Pietenpol-List: seeing the instrumentsJim, That slanted instrument panel idea is by far the best suggestion I've seenon this net in years. I guess the biggest shock or disappointment I had with 41CC was when I first climbed in the reat pit, sat there and saw howclose everythig was to my big nose. As I flew it became more annoying. Ithought, look at all that room ahead in the front pit. How could some of that space be transferred back here. I'm thinking hard on that subject now before I begin my third Piet.Corky, always bringing up controversial thoughts in HOT, HOT Louisiana**************Dell Summer Savings: Cool Deals on Popular Laptops =93 Shop Now! =http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D1)________________________________________________________________________________
RE: Pietenpol-List: seeing the instruments
My solution to that was to put a few instruments in the front panel -compass, airspeed, altimeter and a slip indicator. Works great until I puta passenger in there - then at least they get to know how low we are and howslow we're going.You really don't look at the instruments very much - this is a "seat of thepants" airplane. This past spring, my pitot tube got clogged with pollen,which I didn't notice until I was climbing out after takeoff (apparently Idon't refer to the airspeed indicator for rotation speed). Not a terriblybig problem to fly the airplane with no airspeed indicator. There are manyclues to speed, including the way the stick feels, the sound of the wind inthe wires, etc.Jack PhillipsNX899JP _____
Re: Re: Pietenpol-List: seeing the instruments
