RE: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol Gathering
I wish they did. This is the only flaw I have found with them (so far) and the other online vendors that have reasonable pricing. Besides, these shirts are mostly worn when eating fatty foods, partaking of too much liquor and the telling of lies about love conquests and flying adventures. Who needs glasses and pencils for that?John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2810 Crossroads Drive, Ste 3800Madison, WI 53718Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Jul 6, 2009, at 3:34 PM, Jeff Boatright wrote:> >>> John,>> The shirts look great. At the risk of being a WATB, is there a way > to have Cafe Press include shirts with pockets? I find that t-shirts > with pockets are the Ts I wear the most (gotta put the pencil and > reading glasses somewhere!).>> Thanks,>> Jeff>>________________________________________________________________________________Subject: RE: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol GatheringDate: Mon, 6 Jul 2009 15:58:56 -0400
Re: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol Gathering
Subject: Re: Pietenpol-List: New builder: An IntroductionKen,Sounds perfect, no reason not to start as soon as possible and avoid the rush, as you get more and more into your project and the addiction grows, you will more than likely get her upset with you anyway so you might as well start early, you can start now and come to Brodhead or start later and miss Brodhead, the end result is youre gonna get her upset with you anyway. No woman is that understandingJohn**************Looking for love this summer? Find it now on AOL Personals. (http://personals.aol.com/?ncid=emlcntuslove00000003)________________________________________________________________________________Subject: Re: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol GatheringDate: Tue, 07 Jul 2009 09:33:34 -0400
I have a question about the lower motor mount fittings that are bolted to the lowerfuselage longerons. On the original plans, Bernard shows two small tabs thatare bent at right angles to the fitting. These are the tabs that rest againstthe firewall. My question is how necessary are they structurally? I have somephotos of finished Piets where they are not there, some where the tabs arethere, but butt welded instead of screwed into the longeron as Bernard shows.If the upper tab is screwed in place. it will interfere with the upper cross bolt.The lower tab screw will be very close to the bottom of the longeron. On theoriginal plans, Bernard must have used wood screws to attach the tabs. It appearsthat on the original, these tabs did not add anything structurally, butactually weakened the structure. I realize that welding the left and right halvesof the lower fittings together at the tabs would be better, but is it reallynecessary?I have attached a drawing showing the fiiting.Thanks,Rick Schreiber________________________________________________________________________________Subject: RE: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol GatheringDate: Tue, 7 Jul 2009 11:11:55 -0400
I think each of us build these things slightly different. It is always interestingto inspect other peoples process or technique. When I see some sort of differenceit makes me say, "wow, that's a cool way to do that"... and I oftenwonder, "did I do that right?" I may post a few pics of mine later just to getsome eyeballs on them. I'm nearly 100% certain that mine are just fine. Theymay not be just like others, but they were built to the plans and should workfine. I was sanding several of my ribs last night in preparation for urethane coatingwhen I started to notice that each one is a separate work of art. I cut thegussets in batches, and they were all built in the same jig... so they are nearlyidentical... but to the builder there are noticeable characteristics thatstart to become more evident after handling a part so many times. Great looking work Ken!--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Skinny axles WAS Brodhead Pietenpol GatheringDate: Tue, 07 Jul 2009 11:40:10 -0400
