Original Posted By: "Chet's Mail"
Hi allHopefully everyone hasn't left yet But if there happens to be an 0-235 powered Peit there could some one kindly getsome info on the engine mount measurements pictures etc?Hope you all have a great time and hope to see you there next year.CarsonRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Brodhead 0-235
Pietenpol-List: Re: Shut off Valve
Does any one know of a source for a inlive brass body plug fuel shut off vave. I've checked aircraft spruce and wicks, they have the three and four but no two or inline.Don Hicks piet now has it's 40 hour restriction flown off, YEA.Chet HartleyN920Y________________________________________________________________________________Subject: Pietenpol-List: Re: Shut off Valve
mine is a typical brass body ball valve with nylon seats.could be found at aboutany pipe supply or hardware store.seems to work fine in test.haven't got tofly it yet but soon.I think it is a better option than a plug valve.( and by theway I used the teflon paste sealer in a tube from the auto parts store-seemsto hold perfectly so far with 100 L.L.)I mounted it crossways under the tankoutlet and made an extension rod handle to bring it back under the front panelso it can be operated without reaching clear down under the tank. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Shut off Valve
Original Posted By: "Michael Silvius"
If I correctly understand what you are asking for, you can use the ones available in the plumbing section at your favorite big-box home store. There was an active discussion on the list about these 4-5 years ago, and the conclusion was that they are the same valve that A.S.S. sold at the time for about 1/8 the cost. I believe there are several out there flying on Piets now.Kip GardnerOn Jul 18, 2009, at 8:39 PM, Chet's Mail wrote:> Does any one know of a source for a inlive brass body plug fuel > shut off vave. I've checked aircraft spruce and wicks, they have > the three and four but no two or inline.>> Don Hicks piet now has it's 40 hour restriction flown off, YEA.>> Chet Hartley> N920Y>>________________________________________________________________________________
Re: Pietenpol-List: Re: Shut off Valve
And it will be the same thing that ACS sells you but at ACE hardware it willcost you half as much.Michael in Maine----- Original Message -----
