Pietenpol-List: mag switch setting for start
Re: Pietenpol-List: More Piet vids
#yiv576767795 .hmmessage P{margin:0px;padding:0px;}#yiv576767795 {font-size:10pt;font-family:Verdana;}Sure is lonely with everybody gone to Brodhead and Oshkosh!I'll be starting up the new A75 pretty soon and need to checkon switch setting.- The 65 didn't have impulse on either magand the 75, with new Slicks, has it on both.- I've heard thatthe mag switch should be set to "Left" for starting.- I've alwaysset it to "Both".- Any comments on procedure?Thanks.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net=0A=0A=0A ________________________________________________________________________________Date: Sat, 25 Jul 2009 22:27:46 -0700Subject: Re: Pietenpol-List: More Piet vids
=0A=0A=0A#yiv734885146 .hmmessage P=0A{=0Amargin:0px;padding:0px;}=0A#yiv734885146 {=0Afont-size:10pt;font-family:Verdana;}=0A=0ASure is lonely with everybody gone to Brodhead and Oshkosh!I'll be starting up the new A75 pretty soon and need to checkon switch setting.- The 65 didn't have impulse on either magand the 75, with new Slicks, has it on both.- I've heard thatthe mag switch should be set to "Left" for starting.- I've alwaysset it to "Both".- Any comments on procedure?Thanks.Oscar Zuniga=0AAir Camper NX41CC=0ASan Antonio, TX=0Amailto: taildrags(at)hotmail.com=0Awebsite at http://www.flysquirrel.net=0A=0A________________________________________________________________________________Date: Sat, 25 Jul 2009 23:10:21 -0400
Sure is lonely with everybody gone to Brodhead and Oshkosh!I'll be starting up the new A75 pretty soon and need to checkon switch setting. The 65 didn't have impulse on either magand the 75=2C with new Slicks=2C has it on both. I've heard thatthe mag switch should be set to "Left" for starting. I've alwaysset it to "Both". Any comments on procedure?Thanks.Oscar ZunigaAir Camper NX41CCSan Antonio=2C TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
RE: Pietenpol-List: mag switch setting for start
Oscar,This may help, http://www.aeroelectric.com/articles/Ma ... rWonthaggi Australiahttp://www.cpc-world.com _____
Re: Pietenpol-List: shaky video from first day of Broadhead
Subject: Re: Pietenpol-List: shaky video from first day of Broadhead
I may have had one or two times when the prop kicked backon me a little while trying to hand-prop my A65 with noimpule couplers, but it seemed to only happen when theengine was flooded. In the early days of my ownership ofthe airplane, I was not well versed on starting the A65with Stromberg carb when the engine is warm, and I oftenflooded it. Now that I know how to handle warm starts, Ihaven't had a flooded engine or prop kickback since Idon't remember when.I have noticed, in the very limited amount that I've turned the A75 while fitting the prop, etc., that it is aLOT stiffer than the 65 was. Break-in should improvethat a lot but it seems like it will take a bit more armpower to flip this new prop than it did the old one. Thecompression ratio is exactly the same as on the 65 so Iknow it's the new pistons, rings, and cylinder hone jobas well as all the new, tight-fitting components.Oscar ZunigaAir Camper NX41CCnow A75 poweredSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
