Pietenpol-List: Under wing float gauges
Has any one made their own float gauge? The one that hangs below the wing...cleartube. I am thinking about it. I just finished building the last rib....waiting on Aircraft Spruce. How longdoes it normally take to get a wood package? I still have work to do....sanding,sandingand sanding ribs.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009using Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Under wing float gauges
Jerry,Attached are the instructions that Steve Eldridge made available, usingeveryday stuff. I haven't built the gauge, yet, but even I could understandthis one!Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)-----Original Message-----
Pietenpol-List: Re: Under wing float gauges
Thanks Gary. I believe even I can do that.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009using Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "K5YAC"
Subject: Pietenpol-List: (no subject)Pieters,May I hear from you on the pros and cons of the alternate airfoil # 612, I believe that's it. If anyone is flying this wing would you please contact me off Piet line.ThanksCorky________________________________________________________________________________Subject: Pietenpol-List: Re: Under wing float gauges
