Original Posted By: Bill Princell
Would there be a number of Pietenpol builders that might interested in a crankextension for a Ford engine ? It will fit the standard 6 degree shaft, prop hub, standard on all aircraft engines, I have used this extension on all of myFord and Funk engines. I will produce this item in a CNC, so the more made ,theless cost. The thread end, is now a 1-3/8"--18 EFT , Thd. The weight is 5.5 Lbs, turned from mild steel.This is a standard design, and is out for bids.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/cran ... ______Date: Sat, 15 Aug 2009 00:37:39 -0400Subject: Re: Pietenpol-List: beautiful view from cockpit of landing on 27 at OSH
