Pietenpol-List: Handheld Radio
Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help.ThanksGene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter.________________________________________________________________________________
RE: Pietenpol-List: Handheld Radio
"Tennessee is mine. I've been flying that area for 2 years." _____
Re: Pietenpol-List: Any Piets/Projects in the Freeport IL area?
Re: Pietenpol-List: Handheld Radio
Longest cross cournty I've ever heard of! If you'd use a chart and a compass you might be able to find your way out here. If all else fails, look for a town's name on a water tower. The Mississippi flows South, The Tennessee flows north, the Ohio flows West and if you reach the coast, turn right.Good LuckGene ----- Original Message -----
Subject: Re: Pietenpol-List: Handheld Radio
Hi Rick,Last night ordered the Vertex VXA - 300 Pilot III from www.skygeek.com for $219.00. Aircraft Spruce wants $340.00 for the same radio. I had read somewhere else, some time ago, that it was easier to use that the Icom and it has a better battery, plus it comes with the headset adapter. I mounted a 45 degree antenna under my cowling (using the cowling as my ground plane). I tried it with an old radio I had and it seemed to work just fine, without engine noise. Gene ----- Original Message -----
Original Posted By: brian.e.jardine@l-3com.com
Subject: Re: Pietenpol-List: Handheld RadioPoath________________________________________________________________________________
I am thinking about getting this same radio.... I think it would beperfect for the Piet. You get anything done the wife's new car? Do youwant to meet to get the shear up to your place and exchange the $70? Ithink we could cut up some of that heavy steal angle to send with you tomake a stand.
Sorry for the miss post.
Pietenpol-List: Re: Handheld Radio
Original Posted By: Roman Bukolt
I have the Icom IC-A22 NAV/COM. I don't have a lot of experience with many aviationhandhelds, but I've used a whole slew of Icom, Kenwood, Vertex (Yaesu) radios,and others in various hobbies or other applications. They are all prettygood, but I've come to like Icom's robust audio and ease of use. I've got3 Icom handhelds... one is an old IC2AT 144MHz "brick"... aside from the lackof DTMF tones, it still works great. I also have an 8 year old 4008A FRS radiothat has been through everything (wet, hot, dropped repeatedly) and it too worksgreat. I'm sure other manufacturers offer a decent aviation product line,but I can only speak for the ones I've used personally. As for the NAV feature... it is a great backup for the VOR radio. I actually usedit on one of my cross country flights, just for fun. It works great, andwhy not have a backup? Actually, it will be my only VOR reciever in my Piet.Most likely I won't be doing a lot of cross country anyway, and when I do I'lllikely use my GPSMAP 195, but it will be nice to have the VOR in the event ofa GPS failure. I've never used the Sporty's radios (not sure who actually makes them), but theylook like they operate real similar to the Icom for ~$100 less. Can't speakfor their performance though.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "Lagowski Morrow"
THIS IS MY ICON A24. I HAVE A PPT BUTTON ON THE END OF MY STICK AND THE RADIO IS WIRED INTO MY INTERCOM ON THE LEFT SIDE ( SEE THE PLUGS ABOVE THE WHITE THROTTLE BALL. VERY EASY TO READ, AND CHANGE TO ANY OF 10 CHANNELS PROGRAMED IN.On Aug 10, 2009, at 10:58 AM, Gene & Tammy wrote:> Just ordered a new handheld for N502R and wondering where others are > mounting/keeping them. With each cockpit & panel being somewhat > different, I'd like to see what others have done, before I mount > mine. Photos would be a big help.> Thanks> Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't > do well in the Southern humid heat). Looking forward to winter.>>________________________________________________________________________________
Original Posted By: Gene & Tammy
Gene, I use an older Sporty's handheld radio. The antenna is one of those Cessna bent external ones which I straitened and put behind my seat,.with a cable to the handheld. The radio is strapped to my left leg with a velcro strap glued to the back of the radio. I didn't want to mount it to anything. It works--Jim Lagowski ----- Original Message -----
Re: Pietenpol-List: Handheld RadioI second that. ----- Original Message -----
Great looking cockpit and I like how you located the radio.ThanksGene ----- Original Message -----
Pietenpol-List: Re: metal parts
Original Posted By: "K5YAC"
The one I recall was a fellow that had his work done through emachineshop.com,which offers a neat little 3-D drawing tool that requires you to draw all yourown parts, as they do not allow "second prints" so to speak for anyone otherthan the original customer, or something like that. I actually drew some smallerparts and priced it... very expensive. I can almost picture the guy's website that had the work done... lots of greenin the color scheme of the airplane I believe... and I think he also has an R/Cmodel to match. I have it bookmarked at home, but maybe this will help someonesmemory if we are thinking of the same guy. I may know of a guy... well, shhhhh. I'll let him introduce himself if he wantsto offer services.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: metal parts
Here is the thread I was thinking of http://forums.matronics.com/viewtopic.p ... ineshopAnd this is direct to DJ Vegh's web site http://www.imagedv.com/aircamper/log/im ... 03.htmHope this is what you were looking for.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 10 Aug 2009 16:32:16 -0500
Re: Pietenpol-List: Re: metal parts
Original Posted By: "Michael Silvius"
That was DJ Veigh, I believe.Wayne Bressler Jr.Taildraggers, Inc.taildraggersinc.comSent from the phone that made the Blackberry obsolete.On Aug 10, 2009, at 5:16 PM, "K5YAC" wrote:>> The one I recall was a fellow that had his work done through emachineshop.com> , which offers a neat little 3-D drawing tool that requires you to > draw all your own parts, as they do not allow "second prints" so to > speak for anyone other than the original customer, or something like > that. I actually drew some smaller parts and priced it... very > expensive.>> I can almost picture the guy's website that had the work done... > lots of green in the color scheme of the airplane I believe... and I > think he also has an R/C model to match. I have it bookmarked at > home, but maybe this will help someones memory if we are thinking of > the same guy.>> I may know of a guy... well, shhhhh. I'll let him introduce > himself if he wants to offer services.>> --------> Mark - working on wings>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... __________
"Right after the War finished, barnstorming was like this all the time.." _____
Re: Pietenpol-List: metal parts
Comandante Zuniga:Can't remember anyone real recent posting such an image. At least not withinthe last couple of years. Must be an other list perhaps? I know DJ had hisparts cut by Emachineshop, and I know that would not let clients useprevious job files but then most of DJ's stuff would not likely work for aPietenpol as his was a GN-1su fiel corresponsal:Michael----- Original Message -----
Where are you located? I'm in Camden.Gene ----- Original Message -----
Gene,I'm 3 seconds away in California (by internet). But a few of us have made acommitment to fly our newly finished Piets to Brodhead in 2011. Don't worry,I have your directions down.Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
Original Posted By: "Lynn Knoll"
Subject: Re: Pietenpol-List: metal partsI'd go in on thatLet me knowCheersjonIn a message dated 8/10/2009 6:21:23 P.M. Mountain Daylight Time, aviatorbell(at)yahoo.com writes:As many piets that are under construction, a group of you should get togeather and have 5-10 sets of fittings cut, divide the cost and it would bemuch cheaper. If there were any left over you could hold on to them and sellthem at brodhead or to another local builder who came along. It would help offset the cost a little.(http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Original Posted By: "TulsaFlyer"
This might be the solution for some of you new builders. I just got off the phone with Ken Perkins who lives in Olathe, KS. He has a stock of ready made parts ready to go. He mentioned wing fittings, die spring landing gear shock strut, cabane fittings, lift strut fittings, gear fittings, control sticks, all the flat parts, and complete tail wheel assemblies.His phone: 913-764-6949His email: kenandveraperkins(at)sbcglobal.net________________________________________________________________________________Subject: Pietenpol-List: Re: metal parts
Something along that line may be happening [Wink] ...............Stay tuned!!JodyRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Handheld Radio
I bought an old Delcom because everything is on the end.It came with both a chargable pack and an AA pack.Since the cockpit is small and crouded and I wanted toretain as much antiqueness as possible I didn't wantthis big black flat thing stuck somewhere.Unfortunately, since I live under the busiest airspace inall of Canada I now have to have a transponder. I gotone, a Collins, with sender. It apparently is the shortestone made but it will still be intrusive. Oh well.Cif ----- Original Message -----
Original Posted By: Matt Keyes
Re: Pietenpol-List: Re: Handheld Radio
Original Posted By: "Aircraft Spruce Info"
Now that is what I call customer support! I would like to point out that this is not the first time ACS has responded to our comments here. I'm impressed.Thank youGene in Tennessee----- Original Message -----
http://www.matronics.com/Navigator?Piet ... ______Date: Mon, 10 Aug 2009 14:37:37 -0400
> ** Re: Pietenpol-List: Handheld Radio
>> *>> *>>-- Rick HollandCastle Rock, Colorado"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________Date: Mon, 10 Aug 2009 11:00:55 -0400
http://www.matronics.com/Navigator?Piet ... ntribution ------------------------------------------------------------------------------ Checked by AVG - www.avg.com 08/10/09 18:19:00________________________________________________________________________________
http://www.matronics.com/Navigator?Piet ... nics.com/c _____ - Release Date: 08/10/09 18:19:00________________________________________________________________________________Date: Mon, 10 Aug 2009 17:18:45 -0700 (PDT)
