Pietenpol-List: portable tie downs
Re: Pietenpol-List: Re: ASSCO,inc
Regarding the wedge blocks, I believe they are only required at the two locations shown, as reinforcement for landing gear attachment. Some builders have opted to use lightweight balsa filler wedges in other locations, to avoid water collection in the pockets (not a bad idea).- Regarding plywood, one important feature of Aircraft grade plywood is that it is manufactured using waterproof (actually boilproof) glues. This will prevent the plies from delaminating, should the wood somehow become soaked with water. An economical alternative to Aircraft grade plywood for the fuselage sides is the use of BS1088 or BS6566 Okoume Marine Ply (Okoume is a mahogany-like tropical wood).-While it is not quite as strong as Aircraft ply made of Birch, it is apparently strong enough for this purpose, and is manufactured using waterproof (also boilproof) glues. In addition to the lower cost, it is also lighter (in weight, as well as color) than Birch, and available in 4' x 8' sheets. - A couple of sources for Okoume Marine Ply: - - http://www.noahsmarine.com/ http://www.boulterplywood.com/ - Bill C. - -" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Piet ... cs.comllow target=_blank>http://www.matronics.com/contribution-_________________ - -http://www.matronics.com/Navigator?Piet ... ronics.com -http://www.matronics.com/contribution - --http://www.matronics.com/Navigator?Piet ... tribution-" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Piet ... cs.comllow target=_blank>http://www.matronics.com/contribution" target="_blank">http://www.matronics.com/Navigator?Pietenpol-Lista href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com_blank">http://www.matronics.com/contribution- - - =0A=0A=0A ________________________________________________________________________________Date: Thu, 27 Aug 2009 23:50:55 -0500Subject: Re: Pietenpol-List: Re: ASSCO,inc
RE: Pietenpol-List: Fuselage building and material;exelente
I have to agree with- Gary..we have a MacBeath Hardwood here in SLC, UT and the prices are great I got my Spruce and ply and I don't have to pay shipping costs.-Brian SLC, UT -
RE: Pietenpol-List: Fuselage building and materialokume ply;
Original Posted By: owner-pietenpol-list-server(at)matronics.com on behalf of jorge lizarrag
Jorge,I'm not sure if I understand your question, but if you are asking whether Okoume Marine plywood is okay to use for your fuselage sides, the answer is yes. Many Pietenpols have been successfully built with this plywood used for the fuselage sides.Bill C.-----Original Message-----
Re: Pietenpol-List: Fuselage building and material;exelente
Original Posted By: brian.e.jardine@L-3com.com
One more thing I would not use Okume unless I coated it with epoxy, it's softand you can dent-it with your finger nail, it however soaks epoxy like a spongeand this increases it's side hardness and abrasion resistance.On Wed, Aug 26, 2009 at 3:24 AM, Robert Ray wrote:In the South east you can build out of poplar if you like, you can buy it for a buck a boardfoot, I'm thinking of building out of baltic birch although not boil proof it's stronger and moreflexible than 1088 Okume, probably twice as strong per deminsion and it's CHEAP.The epoxy I'm using will not pass a boil test either. The birch I boil tested the naturalwood fibers broke down just as bad as the glue joints. What I worry about is not somuch a boil test or a good soaking it's high humidity over time. I have a piece of balticbirch on a truck topper I built it's been exposed to rain several times and hasn't delaminated yet.It's shock resistance is amazing. Birch rules, the boat builders rate marine plywoodstrength in this order DF, Meranti then Okume, the Jodel originally was built ofOkume but many are now using GL aircraft birch. I think Meranti is a little cheaper than the Okume but again heavier but stronger, it is more durable and less likly to rotthan either okume or birch.I would not use anything but 1088 if I used Okume I have bent it on other projectsand I think it's 6056 and it will break where it's inner ply's are spliced.If you want to know about okume go to kayak building web sites and there you willlearn. I like the looks if finnished bright with clear epoxy and fiber glass it isa very beautifull wood, it's works excellent and will give a much smootherfinnish than DF.-my 02 cents worth-RussellOn Wed, Aug 26, 2009 at 1:16 AM, jorge lizarraga wrote:ups- tanks for all you inform i used in my plane birch aircraft plywood mm. buy in spruse but the last buy shiping chargers is almost the same amount the wood????if you have thoses scrap pises i like tonow if you like selmy those . --- On Tue, 8/25/09, brian.e.jardine@L-3com.com wrote:
Subject: Pietenpol-List: portable tie down suggestions Dan, A few weeks prior to going to Wisconsin I ordered a set of these from Chief Aircraftand amquite happy with them. http://www.chiefaircraft.com/airsec/Air ... eDown.html FlyTies unique design allows quick insertion and quick removal using the easy-outextraction tool provided. Rugged, die-cast steel rods are 3/8" x 14" for deeperpenetration into harder ground. Cumulative load capacity is 3,600 lbs. Kitsincludes 3 ea. Delrin hubs, 9 ea. steel rods, 3 ea. 3/8" x 12' ropes, easy-outextraction tool, and rugged compact canvas tote bag. Complete kit weighs only6 lbs (Less than 1 gal. of Avgas) and has a lifetime warranty.Mike C. ________________________________________________________________________________Subject: RE: Pietenpol-List: Fuselage building and material;exelenteDate: Wed, 26 Aug 2009 10:30:01 -0400
This may not be the best, but Ill include my favorite. Its simply three, one footpieces of chain each cut into three, four inch pieces. These are joined bya hefty brass hook with a ring to tie to. While youre in the hardware storebuying the chain (theyll cut it for you) purchase nine of the largest nails theyhave (check to assure theyll pass through the links). To get fancy, pickup a fence hammer which also works like pliers to extract the nails. Add threepieces of good rope (also from the hardware store) and place it all in a bag.See enclosed. Obviously, I spend too much time in the hardware store!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/tie_ ... __________
RE: Pietenpol-List: Re: portable tie downs
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of BYD
Good idea, BYD. Log home spikes would work well.Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down)-----Original Message-----
I'd guess he is having the same problem I am. I am able to download and pay for the $35 update from the page you linked to just fine. Doing that every couple of years would be fine with me. But, the card reader that came with the lowrance unit is proprietary and it no longer works, so I have no way to load the file to my flash card. Complicating things further, the flash readers have multiple drivers for different readers, and I don't know which one to use because the sticker fell off my reader long ago. Of course, the web site still takes my money. It just seems that Lowrance could've come up with a better way to update the files and they would've had a few more happy customers.Are we allowed to talk about GPS and flash memory on the Pietenpol forum? Seems almost sacrilege. Steve RuseNorman, OK ----- Original Message -----
Re: Pietenpol-List: Re: portable tie downs
Subject: Re: Pietenpol-List: Re: portable tie downs
RE: Pietenpol-List: Okoume and fuselage gussets
Re: Pietenpol-List: Okoume and fuselage gussets
I know what a Timesert is but what's an Assert?Clif> I am gonna assert myself and you all will be proud of the new me!> > John________________________________________________________________________________Date: Fri, 28 Aug 2009 04:39:19 -0400Subject: Re: Pietenpol-List: Okoume and fuselage gussets
Subject: Pietenpol-List: portable tie downsRyan-the Flyties go in the ground as shown in this photo. In comparison to the Claw, whose spikes point in toward eachother, the Flyties point away or diverge from each other and also do so with a 'radial twist', if you will, as they are driven inthe ground.[cid:image003.jpg(at)01CA27B2.2BECC680]http://www.flyties.com/________________ ... ______Date: Fri, 28 Aug 2009 05:34:41 -0700 (PDT)
Subject: Pietenpol-List: QuestionareI received this and thought that others may be interested in making theiropinions known. Its not to often Tom asks but anyone having an opinion should express it, John Dear EAA MEMBER, Since its founding in 1953 EAA members have served as a dynamic and vibrant force of innovation and change in aviation. The passionate spirit of EAA members has led to a growing and dynamic organization that has expandedalong with the interests of members. I would appreciate your candid response to the survey below because it will help us better serve all EAA members. We want to hear what you have to say!The survey should take only a few minutes to complete. Please complete the survey by September 6.=========================================================== Please take the EAA Membership Survey now! _http://www.zipsurvey.com/LaunchSurvey.aspx?iei ... =1569CACF) =========================================================== I=99ll be personally reviewing the results, along with EAA staff. Your feelings about your EAA membership are extremely important. The feedback you can provide will help us ensure that your organization provides the valued information and programs that you are looking for. Thank you for being a member of EAA and for assisting in this importantresearch. After taking a deep breath and recovering from the excitement of AirVenture Oshkosh 2009 we will be reviewing the results of the convention and begin planning for improvements for EAA AirVenture Oshkosh 2010. Wehope to see you and your fellow members there July 26-August 1! Sincerely, Tom Poberezny, EAA President ________________________________________________________________________________Subject: RE: Pietenpol-List: Okoume and fuselage gussetsDate: Fri, 28 Aug 2009 11:55:24 -0400
Original Posted By: Dan Yocum
You guys are lucky! You have all those cool, grassy strips, surroundedby farm land. Out West, we need a 5lb sledge hammer and steel concrete form stakes toget thru the rocks! Gary--------------------------Gary A. BootheSales ManagerCALPLY Architectural Products DivisionSent from BlackBerry Wireless Device-----Original Message-----
Subject: RE: Pietenpol-List: Re: portable tie downsAnd to boot Bill I thought they said that 1200 lbs was PER STAKE.....that's a bunch of BS.
Re: [piet] Re: Pietenpol-List: Re: portable tie downs
Last time I went to OSH, in the space of an hour we completely snapped inhalf something like 8 out of 12 doggie augers (or as some would call them, a"screw the pooch") in the rock-hard, packed, drought-ridden, cement-likeOshkosh soil trying to get some tent anchors to secure our display tent forthe week. We got desperate and tried The Claw... it worked absolutelybeautifully. Fortunately we sold them, so had a couple extra sets at ourdisposal (and even better, the yellow color matched our airplane perfectly).Not saying that other ideas won't work, and I've seen a couple of good (andmuch less expensive) homebuilt versions of the Claw's basic concept, butit's really hard to beat a design that uses what is essentially a large,straight nail for getting it installed on very hard soil, just as AvWebsaid. Here in Florida, there's not much problem with that, here the issue isholding well enough to stay in at all. Maybe if you mounted a strengtheneddoggie auger through the middle of a bigger Claw?Mike WhaleyMerlinFAC(at)cfl.rr.com----- Original Message -----
Original Posted By: Ross Alexander
Re: Pietenpol-List: Engine question
Subject: Re: Pietenpol-List: Engine question
Just krazy-glue the rope to the rock.Clif> > You guys are lucky! You have all those cool, grassy strips, surrounded> by farm land. > > Out West, we need a 5lb sledge hammer and steel concrete form stakes to> get thru the rocks! > > Gary________________________________________________________________________________Date: Sat, 29 Aug 2009 06:24:02 -0700 (PDT)
Original Posted By: "BYD"
>> The plans do not call for a specific type of plywood to be used. Probably> whatever the norm was back in 1934. I would assume that the glues used today> are superior to those of 75 years ago.> I'm planning to use Marine Okoume throughout my fuselage. I haven't done a> proper material layout, but I think it would be a very tight squeeze to> get ALL of the 1/8" ply parts out of a single 4' x 8' sheet (fuse sides,> fuse and tail gussets, seat bottoms, seat backs, firewall, turtledeck> formers, instrument panels, etc. etc.), so I bought two sheets, which added> a whopping $40 or so to my material costs. But, in the long run, I'm sure it> will have saved me money, since we all end up making a few "extra" parts,> and on the day that I realize that I need a few more square feet of 1/8"> plywood, I won't have to go buy another sheet. Just something to keep in> mind -- especially if you're having plywood shipped.>> Bill C.>> **>> *>> " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List> =nofollow>http://forums.matronics.com> blank rel=nofollow>http://www.matronics.com/contribution> *>> *>> *>>________________________________________________________________________________Subject: Pietenpol-List: Re: portable tie downs
