Pietenpol-List: 2 Corvair Engines
RE: Pietenpol-List: Another sketch
The method-I use to determine whether the gusset is the right size is the following:I measure my gusset, then I compare my measurement to the size shown in the plans. If they match, we're good to go.I know, this sounds like a joke, but it really isn't.The plans call for the fuselage gussets to be 1/8" x 2 1/4" and cut in lengths to fit. So the correct size of the gussets for this plane will be 2 1/4" wide, and just long enough to cover the diagonals and uprights. Making the gussets longer than that will-add weight, and use more plywood, but will provide very little additional strength. Making the gussets shorter-could result in a considerably weaker joint.The size of a required gusset could be determined by taking into account the forces expected to be acting upon the joint, coupled with the strength of the various materials, and the strength of the adhesive. Then, the bond area (the contact between frame and gusset) could be calculated, and from that the configuration of the gusset could be established.I'm sure that IF someone with the proper technical background was so inclined,-and performed a detailed structural analysis of the fuselage structure, they would probably find that the 2 1/4" dimension might be a bit of "overkill" in certain areas. Maybe in certain locations-the gussets-would only need to be 2", or 1 7/8" or whatever. Sounds like a lot of work with very little benefit. If we keep in mind that this aircraft was designed by a man with no formal education in aircraft design, and was designed 80 years ago, to be built by an average person with no special skills or equipment, it becomes easy to see why the gussets are all the same width. It keeps-things simple. Simple-is good. Set the fence of the table saw at 2 1/4", and run a sheet of plywood through, to produce strips which can be easily trimmed to length-to suit each location.One thing we do know for sure is, that when built to the plans, the thing works.-Bill C.----________________________________________________________________________________Subject: RE: Pietenpol-List: Another sketchDate: Fri, 4 Sep 2009 14:08:37 -0400
I bought one of those ($99.00 at Home Depot) and it has come in handy many, manytimes in the 8 months I've had it.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: 2 Corvair Engines
Re: Pietenpol-List: Handy tool: Dremel Multi-Max Oscillating Tool
Original Posted By: Bill Princell
I've got 2 1965 "RH" block Corvair engines for sale. Just decided that I wantto rebuild a Continental instead. I took a wrench to the lot where they wereand made sure they turned. They've been in my garage ever since. Also, havethem on wooden cradles with casters so they can be rolled around the garage. $275 for each engine/cradle.Northeastern, CT. Can deliver within a reasonable distance (about 100 miles) frommy house for an additional charge depending on distance. Email me off-list.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 4 Sep 2009 11:15:35 -0400Subject: Re: Pietenpol-List: Handy tool: Dremel Multi-Max Oscillating Tool
Re: Pietenpol-List: 2 Corvair Engines
Glenn, for what it's worth. While I was completely rebuilding my A 65 I found that " Woody Herman 715-967-2119 1-800-279-3168" had the best prices on new & used parts. A really good guy to deal with. If you call, leave a msg and he will always get back to you.I love my A 65 and find it has plenty of power, even on hot days, for my Piet. I'm running a Jay Anderson 76X38 prop and the combination is everything I could hope for. I don't feel any need to upgrade to a 75 or 85. Climb is all I'm concerned with, and it does it very well. If I wanted to go faster, I wouldn't be flying a Piet.Gene in TennesseeN502R----- Original Message -----
Re: Pietenpol-List: Another sketch
I am on the list....just kind of quiet. Glad you enjoyed the pc.Mike Cushway--------PAPA MIKERead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ______Date: Fri, 4 Sep 2009 12:39:07 -0500Subject: Re: Pietenpol-List: Another sketch
Like Jack Phillips and several others on this list, I do have anaeronautical engineering background. However, I think we all agree thateighty years of proof-by-pudding beats all heck out of theory and analysis.Build to plan.Mike Hardaway _____
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________________________________________________________________________________Date: Fri, 4 Sep 2009 12:30:15 -0700 (PDT)
