Subject: Pietenpol-List: Interesting picture> I was at an aviation event on the weekend, and there were a couple of> Piets there, and one of them had an interesting encounter on the > way to> the event. Apparently, at about 2400 ft altitude, a bird hit the plane> (from the front). It struck one of the cabanes, and left a calling > cardbehind. Must have been a real fright for the front passenger!> > Bill C.> ________________________________________________________________________________
RE: Pietenpol-List: Interesting picture
".Must have been a real fright for the front passenger!" To say nothing ofwhat the bird thought of it! _____
Re: Pietenpol-List: Interesting picture
Subject: Re: Pietenpol-List: Interesting pictureDid the bird the the Piet from the front or rear? :-}Steve D----- Original Message -----
Wish that picture had not been published..here comes PETA..Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(15 ribs down.) _____
Pietenpol-List: No RPM drop on mag check??
Original Posted By: H RULE
Dan;I'm going with defective ignition switch, or probablymore likely, improperly wired. Shouldn't be verydifficult to troubleshoot, but shut off the fuel andground the P-leads before you mess with it. You'llneed to pull the cowling enough to get to the magP-leads or at least be able to get a continuitymeter onto the leads. You'll also need someone tomove the switch while you check each one.Obviously the "off" and "both" positions work rightso something else is funny in there.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Tue, 15 Sep 2009 18:15:51 -0700 (PDT)
