Pietenpol-List: 106 years ago today-prelude to flight
Pietenpol-List: exhaust manifold [was Re: humped center section]
Doug,DON'T attempt to weld Titanium with an oxyacetylene rig UNDER ANY CIRCUMSTANCES.When Ti is ignited, it burns with a white flame, way above 2500 degrees, and canignite anything in it's vicinity. If it's to be welded it MUST be done in aninert atmosphere, as with Mig or Tig.My .02.--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 28 Oct 2009 09:15:51 -0400
Original Posted By:> tkreiner(at)gmail.com
Tom=2CDin't realize I put Ti in with gas welding. would be kinda like trying to weld Magnesium.Doug DeverIn beautiful Stow Ohio> Subject: Pietenpol-List: exhaust manifold [was Re: humped center section]
RE: Pietenpol-List: RE: exhaust manifold VHT header paint, ceramicoat
I used clear VHT paint on the exhust, but it wouldn't fit in the oven so Inever got the full effect of it. It lasted well for about 4 years but isbeginning to rust now. I thought about pulling the exhaust and beadblastingit and then repainting but being the lazy sort, I just sorta ignored it.Jack PhillipsNX899JPRaleigh, NC _____
I had the exhaust on my powered parachute ceramic coated about 8 yearsago, still going strong and still looks good.BrianSLC, UT
> To: pietenpol-list(at)matronics.com> > > Doug=2C> > DON'T attempt to weld Titanium with an oxyacetylene rig UNDER ANY CIRCUMSTANCES.> > When Ti is ignited=2C it burns with a white flame=2C way above 2500 degrees=2C and can ignite anything in it's vicinity. If it's to be welded it MUST be done in an inert atmosphere=2C as with Mig or Tig.> > My .02.> > --------> Tom Kreiner> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 801#269801> > > > > > > ============================================> > > _________________________________________________________________Windows 7: It helps you do more. Explore Windows 7.http://www.microsoft.com/Windows/window ... ______Date: Wed, 28 Oct 2009 07:59:29 -0700 (PDT)
