Pietenpol-List: Bernard Pietenpol - Corvair Oil Pan Conversion
Original Posted By: "dwilson"
Mr Lowell,Have you changed the spar positions when you've changed the airfoil, or you haveleft them exactly where they are on FC10?Regards,Ivan TodorovicRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Bernard Pietenpol - Corvair Oil Pan Conversion
Here are a couple of Pictures of a Corvair Oil Pan that had the ears welded onby Mr. Pietenpol.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/pan2 ... __________
Re: Pietenpol-List: Bernard Pietenpol - Corvair Oil Pan Conversion
Thanks to all of you for your replies. They helped the old brain better see things.I have used my eraser. I will use the cord line - it is about two degreesdifferent.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 20 Nov 2009 13:58:23 -0500Subject: Re: Pietenpol-List: Bernard Pietenpol - Corvair Oil Pan Conversion
Re: Pietenpol-List: Re: General Pietenpol questions
Original Posted By: "njones"
Negel, if you haven't already joined, I would suggest joining the Yahoo Flybaby List. There are some on that list that are from your area and at least one that I know of that has flown both the flybaby and the Piet. I would suggest belonging to both lists to anyone that is building or owns a wooden airplane. Lots of good info and frendly folks.GeneN502R in sunny & beautiful Tennessee----- Original Message -----
Original Posted By: Dan Yocum
