Pietenpol-List: covering question-drain grommets
RE: Pietenpol-List: covering question-drain grommets
Original Posted By: lnawms(at)yahoo.com
Re: Pietenpol-List: covering question-drain grommets
Original Posted By: airlion
of course, if you go even faster, the suction will actually make you go backwards . . . Gene ----- Original Message -----
Original Posted By: wizzard187(at)aol.com
I dought that it could create that much suction. Remember there are many other holes in the wing not creating much suction. Root rib comes to mind. We had them on the Tri-Pacer and the fabric did not even concave at all. and that was at 125mph. And those ribs were not any stronger than the Piets.Doug DeverIn beautiful Stow OhioDate: Tue=2C 24 Nov 2009 07:17:57 -0800
Pietenpol-List: Re: How to be a proper Pietenpol passenger
Greg What town is that? I went to high school in Stillwater, MN so I'm sort of a MudDuck...DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Unless you have absolutely sealed off the wing panel, full ply covered inner end, etc,then there will be more than enough air entering the panel to take up the space ofthe air sucked out. :-)Maybe you should use gronicles instead.Clif"A person learns to skate by staggering about and making afool of himself; indeed, he progresses in all things bymaking a fool of himself." -- George Bernard Shaw, playwright Subject: RE: Pietenpol-List: covering question-drain grommets I dought that it could create that much suction. Remember there are many other holes in the wing not creating much suction. Root rib comes to mind. We had them on the Tri-Pacer and the fabric did not even concave at all. and that was at 125mph. And those ribs were not any stronger than the Piets. Doug Dever In beautiful Stow Ohio________________________________________________________________________________
At what point did this go from being a very strong leg-pulling to being taken seriously?? (except my original post where I suggest that there may be a small incentive to using grommets rather than merely punching holes)Gene ----- Original Message -----
Re: Pietenpol-List: Re: How to be a proper Pietenpol passenger
Original Posted By: "yocum137"
Hi Dan,It is the town of Northfield, MN. A slightly higher resolution photo is attached. It is only a few miles from Stanton where NX18235 is based and is a nice 15 - 20 minute ride for first time passengers.Greg Cardinal----- Original Message -----
Ah that must Carlton's campus - I looked at the google map of St. Olaf and couldn'tsee a lake any where around.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 27 Nov 2009 08:48:51 -0500
