Re: Pietenpol-List: Re: Pietenpol-List Digest: 12 Msgs - 12/01/09
gcardinal(at)comcast.net wrote:> I don't have exact numbers for control forces but I can say that pitch on > NX18235 can be controlled with a light fingertip touch in cruise. Aileron > control requires a bit more effort. Rudder is very light also.> Slowing down for landing lightens the ailerons significantly.> > Control cables shouldn't be tightened any more than necessary to remove > slack. Too much tension will cause unwanted friction.> > Greg C.> > ---Thanks Greg,That is helpful. I have made some aluminum blocks with 1 1/4" sheaves to replacethe hardwood guide blocks that were installed on my project. The elevatorcontrols seemed heavy when I rigged the cables. The cable changes direction about15 deg. now but runs nice and smooth with little friction. I did not wantto put too much stress on the elevator control horns but have enough tensionto avoid flutter. Maybe I am being too concerned.--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 2 Dec 2009 06:37:11 -0600Subject: Re: Pietenpol-List: Re: Pietenpol-List Digest: 12 Msgs - 12/01/09
Re: Pietenpol-List: Fuselage bottom gussets
Subject: Pietenpol-List: Of possible interest: Air & Space article on automotivevs. aircraft enginesArticle title: POWER STRUGGLE: Why car engines can't flyArticle source: Air & Space Smithsonian magazine, Jan. 1997Author: Don Sherman________________________________________________________________________________Date: Wed, 2 Dec 2009 07:17:24 -0700Subject: Re: Pietenpol-List: Fuselage bottom gussets
