Pietenpol-List: firewall question
I'm sort of new here, and just acquired a Piet. project. It had a corvair mounted but the entire plane had been diassembled for a rebuild before I bought it. The firwall was removed and I was wondering what you guys that are using the Corvair have for firewalls? Thanks. Larry________________________________________________________________________________
RE: Pietenpol-List: firewall question
Larry,I am using 14 ga galvanized.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(15 ribs down.) _____
Pietenpol-List: Re: firewall question
Original Posted By: "Larry Vetter"
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________________________________________________________________________________Subject: Pietenpol-List: Re: firewall question
Pietenpol-List: Re: Winter Nap
Original Posted By: "K5YAC"
Thanks Gary for the reply, and photos. Actually the wood firewall has been removedand I was wondering if you guys are using 1/4" or 1/8" ply for the wood firewall. LarryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Winter Nap
Re: Pietenpol-List: Re: firewall question
And -8 Reaumur. [Shocked]--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: firewall question
Original Posted By: Larry Vetter
1/8"------Original Message------
Re: Pietenpol-List: Re: Winter Nap
All this talk about putting the fine machines away for the winter!! I flew last Fri and Sat and will go out again this weekend. This is a time with smooth air and no bugs on the prop. It's supposed to hit 30 degrees on Sat.Dick N.St. Paul, Mn.----- Original Message -----
Original Posted By: airlion
Re: Pietenpol-List: firewall question
Subject: Re: Pietenpol-List: firewall question
