Pietenpol-List: Corvair Cowl Info 6 - Last One
5 of 6Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/cowl ... ___Subject: Pietenpol-List: Corvair Cowl Info 6 - Last One
Pietenpol-List: Re: Corvair Cowl Info 6 - Last One
You're on track on 1-3, Tim. On 4, the front piece is split horizontally to allowremoval. The split is joined by 3 screws on each side of the prop. Whenthe cowling's removed the top part of the nose piece goes with the top of thecowl (riveted) & the bottom part of the nose piece goes to the bottom of the cowl(riveted). The dipstick sticks out of a hole in the top piece. I have a door on top to addoil. The bottom piece has a hole cut out for the air filter and a notch toaccess the gascolator. I just got a hangar in georgetown and, if people will quit attacking IRS buildingsout of georgetown, I'll get the plane there and you can come look. 10 minutesafter I took off from Austin to fly to Houston to pick up the plane yesterday,that jerk hit the building. Got to Houston & checked notams. Sure enough:Georgetown closed. Came back to Austin plane-less. Going to try to get iton Sunday if weather & flight availability cooperate.KevinRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Red Betsy?
Subject: Re: Pietenpol-List: off topic: airways beacon questionMike , In answer to your question about acee decee. Did Tiger have on white or pink drawers during his press conference?________________________________________________________________________________Subject: Pietenpol-List: Re: Red Betsy?
Re: Pietenpol-List: Re: Red Betsy?
Original Posted By: Jim Ash
I had to show the leading man how to lift Alison Elliott,into the rear cock-pitwithout allowing her skirt to attach to the edge of the cockpit combing, it tooka few trials to get it right.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 19 Feb 2010 15:45:43 -0500 (GMT-05:00)
Pietenpol-List: Re: off topic: airways beacon question
Subject: RE: Pietenpol-List: off topic: airways beacon 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________________________________________________________________________________Subject: Pietenpol-List: Re: off topic: airways beacon question
Original Posted By: Dan Yocum
Mikeee-It depends on whether it's an arc tube lamp, ballasted, or just a coiled filamentlamp. I would think that a coiled filament wouldn't care if it sees AC orDC as long as it was the right voltage.Right?And hey, let me know when you have that thing turned on. Point it south and I'lllet you know if I see it from here ;o)--------Oscar ZunigaSan Antonio, TXAir Camper NX41CCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 19 Feb 2010 16:58:18 -0600
Original Posted By:> Lowellcfrank(at)yahoo.com
Or in Pieti speak "after two hundred and forty tries and 38 torn dresses we got it right"... =3B)> Subject: Pietenpol-List: Re: Red Betsy?
Original Posted By: airlion
Subject: Re: Pietenpol-List: off topic: airways beacon questionI see from a web search that the beacons were powered by a generator. This would most likely make them ac. Check out the volts and number on the bulb. You could easily change the bulb base to make it anything you want.Howdymaster electrician________________________________________________________________________________Date: Fri, 19 Feb 2010 15:55:55 -0800 (PST)
Re: Pietenpol-List: It's a plane
Great news!!Gary Boothe ------Original Message------
Re: Pietenpol-List: Fw: First flight pictures
Original Posted By: VAHOWDY(at)aol.com
> To: pietenpol-list(at)matronics.com> com>> > I had to show the leading man how to lift Alison Elliott=2Cinto the rear cock-pit without allowing her skirt to attach to the edge of the cockpit combing=2C it took a few trials to get it right.> Pieti Lowell> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 242#287242> > > > > > > ============================================> > > ________________________________________________________________________________
