Pietenpol-List: Sky Scout..."Glue"question?
If anyone is a member or subscriber to "Fine Woodworking",they ran a glue comparison in August of 2007 on sixof the common wood glues, here:http://www.finewoodworking.com/Material ... d=28897I'm not a member so I can't access the article but Ithink I remember the results and Gorilla Glue didn'tplace too well in the tests. My own experience withit has NOT been on airplane stuff but what I've foundis that even with the air squeezed out of the containerand the container tightly capped, the stuff will setup on the shelf and be useless so there's no point inbuying more than you can readily use. It also foamsout of the joint considerably, if you care about that.It's T88 for me...Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net ________________________________________________________________________________
Re: Pietenpol-List: Sky Scout..."Glue"question?
There were two glue articles.Here is the first one.Greg Cardinal----- Original Message -----
And the second one....Greg----- Original Message -----
Thanks!Ray Krause----- Original Message -----
Thanks, again!Ray Krause----- Original Message -----
