Pietenpol-List: A Piet is a Piet
Pietenpol-List: Re: A Piet is a Piet
Original Posted By: Dan Yocum
LarryI was indeed a beautiful day even in my rental 150 around Batesville/Mtn. View.Where was the EAA function?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 02 Mar 2010 11:19:58 -0600
Re: Pietenpol-List: A Piet is a Piet
Lawrence, Thanks for one of the best and enjoyable postings I've read in a long while. Next time you'd better carry oxygen with ya! Who knows what a Piet will really do?Gene N502R ----- Original Message -----
Subject: Re: Pietenpol-List: A Piet is a Piet
Original Posted By: Max Hegler
Larry:One must breath the exhaust of a Ford to have such a flight, A cure would be, trylooking off to the right in place of the left for the first 20 minutes aftertake off.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Fw: CorvAircraft> Dimpletape on a propeller
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________________________________________________________________________________
