Pietenpol-List: PIetenpol Wood
Re: Pietenpol-List: PIetenpol Wood
RE: Pietenpol-List: ELT - EPIRB Shopping
No. The only time you might get checked is if you have a ramp check by thefeds. An inspector from the FSDO did my A/W inspection and never askedabout the ELT. ELT's are not required during flight testing an aircraft.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Re: Pietenpol-List: Piet project for sale
I am interested if the wings are finished.------Original Message------
Pietenpol-List: Re: PIetenpol Wood
I may consider an m-cycle trip to your spot. It will take some convincing of myspouse, however. She rides also and went with me to Brodhead last year. Thistrip would be about 1/2 the distance. We would just need a place to pitch3 person backpack tent and park 2 m-cycles. I will definitely be interested ifthere is going to be a good show of airplanes to look at. The more I do onthe GN-1 the more questions I have.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: PIetenpol Wood
Re: Pietenpol-List: weekend cowl work
Subject: Re: Pietenpol-List: weekend cowl work
Pietenpol-List: Re: Piet project for sale
I would order some mixing syringes and tips for your T-88. I have been squeezingmine out of the bottle and it is a challenge to keep the proportions correct.I haven't had a lot of gluing to do as I am just making modifications. Oneof our EAA members used the mixing syringes and came up with a way to cleanthem. I may see him tonight and will ask him. They seemed to be the real dealand probably reduce glue waste.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 7 Apr 2010 13:25:34 -0500Subject: Pietenpol-List: Re: Piet project for sale
Re: Pietenpol-List: Re: PIetenpol Wood
Subject: Re: Pietenpol-List: Re: PIetenpol Wood
No need to complicate things any more than necessary. You can mix T-88 easily enoughby eyeballing it. EAA's "How to Glue Gussets" video gives a very simplemethod using a crushed pop can:http://link.brightcove.com/services/pla ... 316095Some popsicle sticks from the local craft store to mix and you are ready to go.You can make a small test piece from scrap wood with your mixed batch of glue,and you can destroy it later to test if you are at all worried about the qualityof your mix.RyanOn Apr 7, 2010, at 1:23 PM, coxwelljon wrote:> > I would order some mixing syringes and tips for your T-88. I have been squeezingmine out of the bottle and it is a challenge to keep the proportions correct.I haven't had a lot of gluing to do as I am just making modifications. One of our EAA members used the mixing syringes and came up with a way to cleanthem. I may see him tonight and will ask him. They seemed to be the real dealand probably reduce glue waste.> > Jon Coxwell> > --------> Jon Coxwell > GN-1 Builder> Recycle and preserve the planet> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 366#293366> > > > > > > > > > ________________________________________________________________________________Date: Wed, 7 Apr 2010 13:50:51 -0500Subject: Re: Pietenpol-List: Piet project for sale
Original Posted By: at7000ft(at)gmail.com
Check out the eaa video section on woodworking T-88 is not critical to ratios.Doug DeverIn beautiful Stow OhioDate: Wed=2C 7 Apr 2010 12:32:43 -0600Subject: Re: Pietenpol-List: Re: PIetenpol Wood
Original Posted By: Jeff wilson
Didn't Jim Markle provide a mixing ratio sheet a long time ago? It had the exact weight of each part in a handy column format.I may be wrong about the source of the info, but a quick archives search might turn something up. Sorry, I can't easily search the archives on my phone...Wayne Bressler Jr.Taildraggers, Inc.taildraggersinc.comOn Apr 7, 2010, at 2:32 PM, Rick Holland wrote:> The alternative to that is measure by weight. I use a digital postal > scale, and non-waxed tiny paper cups from the grocery store. > Measurement by weight is not 50/50 as is measurement by volume.>> rick>> On Wed, Apr 7, 2010 at 12:23 PM, coxwelljon > wrote:> >>> I would order some mixing syringes and tips for your T-88. I have > been squeezing mine out of the bottle and it is a challenge to keep > the proportions correct. I haven't had a lot of gluing to do as I > am just making modifications. One of our EAA members used the > mixing syringes and came up with a way to clean them. I may see him > tonight and will ask him. They seemed to be the real deal and > probably reduce glue waste.>> Jon Coxwell>> --------> Jon Coxwell> GN-1 Builder> Recycle and preserve the planet>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 366#293366>>> ==========> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> ==========> http://forums.matronics.com> ==========> le, List Admin.> ="_blank">http://www.matronics.com/contribution> ==========>>> -- > Rick Holland> Castle Rock, Colorado>> "Logic is a wreath of pretty flowers, that smell bad">>________________________________________________________________________________
Bill:There is a semi abandoned project at Bowman field in Livermore Maine. As Iunderstand it was built by the local EAA chapter. Fuse is complete as arethe wings.Michael in Scarborough, Maine that is...________________________________________________________________________________Date: Wed, 7 Apr 2010 15:18:59 -0600Subject: Re: Pietenpol-List: Re: PIetenpol Wood
I've simply squeezed equal lengths of the materials into a scrap microwave dinner dish, which alas, we have plenty of. Works good.David Paule> I would order some mixing syringes and tips for your T-88. I have been > squeezing mine out of the bottle and it is a challenge to keep the > proportions correct. ________________________________________________________________________________
