Pietenpol-List: Peter's Wiring Diagram
Peter,I would also like to compliment you on your wiring diagram. I was just aboutready to post a request for info, but decided to check the archives, first,and found an old post! Hope you don't mind that I have regurgitated it here.I was looking for something simple...no lights, no radios, no glass panel,no GPS, no night terrain following..... Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(18 ribs down.)-----Original Message-----
Pietenpol-List: horiz stab and elevator
So I started the construction of the horizontal stab and elevator tonight.- I have one question.- What size wood are you using on the beams between the LE and TE on the sides.- I was going to use a piece of 1"x1" the same as the main beam just not routed out.- What is your thoughts?BillRead this topic online here:http://forums.matronics.com/viewtopic.p ... enpol-List" target=_blank>httef="http://forums.matronics.com/" target=_blank>http://forums.matronics; - - - ---- List Contribution Web Site -================== =0A=0A=0A ________________________________________________________________________________
RE: Pietenpol-List: Peter's Wiring Diagram
Gary,The original KISS technique!!ThanksPeter-----Original Message-----
Re: Pietenpol-List: horiz stab and elevator
Original Posted By: bcolleran
that is great- for my case I used the same way to australian piet building laminate le and beams not router I don have it the web side from australian iswww.cpc-world.com these give you alot ideas easy way and safe and include video for the first fly and my tail used same as plans in these moment 3/4by 1" i think , i hope these help you and we seyou nex jorge from hanford--- On Tue, 5/11/10, bcolleran wrote:
Re: Pietenpol-List: Peter's Wiring Diagram
So I started today on the horizontal stab as the first piece that I am building.I have about enough room to slide a piece of paper in the tightness of my fitbetween my diagonal braces. Is that too much or will the t-88 expand and makeup for it?Thanks,BillN424BKRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 12 May 2010 14:31:43 -0600Subject: Re: Pietenpol-List: Peter's Wiring Diagram
> > Pietenpol-List: Peter's trim
Pietenpol-List: Re: tightness of fit?
that is what I was thinking. thanks for the help.BillN424BKRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: tightness of fit?
Probably just getting picky here, but T-88 will not expand to fill the gap.It will bridge small gaps, but it does not expand.If the gaps are too large, and you're using straight T-88 (no fillers) you willcome back later to find that some of the glue has run out of the joint. But inyour case, with a gap the thickness of a piece of paper, you shouldn't haveany problem.That polyurethane Gorilla Glue stuff does expand. But I wouldn't use that glueon my airplane. It isn't really strong enough for aircraft structural applications.BCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 12 May 2010 22:15:14 -0700 (PDT)
