Subject: Pietenpol-List: Mike's Cuy's DVD$25 US dollars to PO Box 736, Berea, OH 44017. Includes Priority Mail shipping.2.5 hours long, plays on DVD players not computers. Not sure Scotty if the NTSCformatwe use here in the US will play in Oz since your players normally need DVD's inthe PALformat last I knew. Mike C. ________________________________________________________________________________Subject: Pietenpol-List: A question about fuselage cross-pieces
Just recently joined the sides of my fuselage together, and was asked how I decidedwhich way to orient the 1/2" x 1" cross-pieces and diagonals on the top andbottom of the fuselage. i.e. when viewed from above, are the cross-pieces 1/2"wide or 1" wide?I don't think it really makes any significant difference, and the plans don't reallysay which way they go. I went with the 1" dimension when viewed from above.My decision was based on the highly scientific method wherein one looks atthe plans, and decides that the cross-pieces appear to be drawn about the samewidth as the longerons (which we know are 1" x 1").Anyway, I was just curious as to what the consensus is out there in Piet-builderland (if there is a consensus). So the question is: Which way did you orientyour top and bottom fuselage cross pieces?Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/tail ... ______Date: Fri, 21 May 2010 17:08:13 -0700 (PDT)
Re: Pietenpol-List: A question about fuselage cross-pieces
RE: Pietenpol-List: A question about fuselage cross-pieces
Mine have the 1" dimension in the vertical direction. Yours will fall outof the sky if you don't change it.I can't believe it makes any difference and it was too long ago for me toeven begin to remember my reasoning on doing it the way I did.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Re: Pietenpol-List: Flap over Flaperons
