Original Posted By: Dan Yocum
2010 1:53:23 PM=0A Pietenpol-List: Cork Floats=0A=0A--> Pietenpol-
RE: Pietenpol-List: Re: New cylinder - low oil pressure?
Dan, it might not hurt to pull the oil sump and give it a good cleaning.That would also let you remove and clean the oil pickup tube, to verifythere are no pieces of rag in it. Check with Poplar Grove and see if theyhave a replacement gasket or you will have oil leaks for sure.And I had suggested maybe trying a different oil pressure gage, nottemperature gage. My gage went bad this year on the way to SNF, so I knowit can happen.Good luck with it. Hope to see you in a couple of weeks at Brodhead.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Re: Pietenpol-List: Re: New cylinder - low oil pressure?
