Pietenpol-List: WX forecast- update for Brodhead-South winds abound
Pietenpol-List: Re: Pietenpol Directory Update
If you would like to include your information in the directory, please fillout the attached Word document and return to my home email jack(at)textors.com.Just include the information you wish. I won't plan to post it to my siteor any other. After I compile the information, I will make it available viaemail in some form; I'm thinking a Word, Excel or PDF doc might be the best.Looking forward to Brodhead then the other show, thanks!JackKDSM________________________________________________________________________________Subject: Pietenpol-List: Re: Pietenpol Directory Update
Pietenpol-List: Re: Construction has begun!
Original Posted By: "K5YAC"
The attached file is a .dat, which is not recognized by my computer or by MS Word...Can you re-post the item, with a .doc format?Thanks,--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Construction has begun!
Wow Chuck... great looking shop indeed! And the assembly line you have set up...you will find that process to be very beneficial, as you probably already knowfrom your obvious organizational skills.Like Jim said... those first few ribs are great. A real neat feeling to completethe first few pieces of your project. I'm looking forward to watching yourprogress.--------Mark ChouinardFinishing up Wings - Working on Center SectionRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Yep, I like your reality much better Dan.--------Mark ChouinardFinishing up Wings - Working on Center SectionRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Construction has begun!
Re: Pietenpol-List: Re: Construction has begun!
I see a copy of Fine Woodworking magazine, as well as a Bush/Cheney campaign sign.Yep, good things should be ahead.--------Mark ChouinardFinishing up Wings - Working on Center SectionRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 19 Jul 2010 09:16:19 -0600Subject: Re: Pietenpol-List: Re: Construction has begun!
Original Posted By:> hangar10(at)cox.net
I see what looks like Glen-L boat plans pinned to the wall.> Subject: Pietenpol-List: Re: Construction has begun!
