Pietenpol-List: Wx update (Chicago forecast) Brodhead
Still tuned in....I have to wonder about the purpose of a HALF SCALE Pietenpol. It's much easierto fly real airplanes than RC models, and for not all that much more effort hecould build a full sized version and do side-by-side formation flying with you.--------Bill FrankRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Wx update (Chicago forecast) BrodheadDate: Tue, 20 Jul 2010 06:39:23 -0400
Pietenpol-List: Re: Wx update (Chicago forecast) Brodhead
Original Posted By: "Kringle"
FYI Madison Ch 27 WeatherBrodhead weather (38 mi. south of Madison) on Wednesday : winds 19 - 10 SW temp below 80sunny all morningOn Jul 20, 2010, at 5:39 AM, helspersew(at)aol.com wrote:>> Wednesday> Mostly cloudy> HI> 86=B0> LO> 72=B0> Partly sunny, warm, moderately humid. Best chance of storms shifts > downstate. Southwest winds 5 to 14 mph possible turning southeast at > the beaches in the afternoon and lowering shore readings a few > degrees.> Thursday> Mostly cloudy> HI> 93=B0> LO> 77=B0> Cloudy periods, quite humid. Clusters of downpour and gusty storms > affecting up to 70 percent of the area. Storms may scatter turning > partly sunny, breezy, hot and humid beyond mid-afternoon.> Friday> Partly cloudy> HI> 97=B0> LO> 72=B0> Sun and cottony clouds, fairly windy, hot and humid. 2010's highest > readings to date possible. Strong storms and gusty winds threaten > afternoon and evening. Storms may affect 60 percent or more of the > area.> Saturday> Mostly clear> HI> 90=B0> LO> 68=B0> Mostly sunny and quite warm but with noticeably reduced humidities. > Scattered thunderstorms may develop in far south su>>________________________________________________________________________________Subject: Pietenpol-List: Re: Wx update (Chicago forecast) Brodhead
I don't believe these guest who are posting this hot forecast. Check Madison channel 27 forecast for yourself! http://www.wkowtv.com/Global/category.a ... --JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: carb rebuilder?
Hey,I'm looking for a good shop to rebuild my Marvel carb from the 0200. Anysuggestions? Contact info would be appreciated too.Thanks,Douwe________________________________________________________________________________Date: Tue, 20 Jul 2010 10:04:01 -0500Subject: Re: Pietenpol-List: carb rebuilder?
Original Posted By: Dan Yocum
Pietenpol-List: Big Piet meets little Piet
For anyone interested in progress photos of the 50%scale model of 41CC, I scanned some pictures and uploadedthem here:http://www.flysquirrel.net/piets/model.pdfThey are lousy quality but you get the idea. And I amnot the builder but I'm very interested in the finishedproduct.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net _________________________________________________________________The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.http://www.windowslive.com/campaign/the ... ______Date: Tue, 20 Jul 2010 13:57:54 -0400 (EDT)
Re: Pietenpol-List: Re: Wx update (Chicago forecast) Brodhead
Original Posted By: Roman Bukolt
FYI- Brodhead is 32mi. south of Madison, 97mi. north of Chicago. Living in Madison and often flying down to Brodhead, I've found Brodhead weather to be identical to Madison's.Roman Bukolt NX20795 See y'all down there!On Jul 20, 2010, at 6:36 AM, Kringle wrote:>> Weather.com shows a much more favorable forecast.>> --------> John>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: New cylinder - low oil pressure?
Mine starts out at 30psi but sometimes drops down to 25 after maybe 20 - 30min. of flight.R Bukolt NX20795On Jul 20, 2010, at 6:12 AM, Dan Yocum wrote:>> Oscar and others with A65 or A75s,>> Sorry to belabor the issue - what's your idle oil pressure after > you've been flying for 30 or more minutes? That's when mine is > 15psi. I know 10psi is acceptable, but Don and others have said > that theirs remains at 35-40.>> After this, I'll put this issue to bed and enjoy flying it. :-)>> Again thanks to all you guys who have put some time and energy into > this thought process - you truly are a great bunch of people! I am > humbled and honored.>> Dan>>> On 07/19/2010 09:56 PM, Oscar Zuniga wrote:>>>> Initial cold oil pressure was 45-50 and only fell to about 42>>> when the temp climbed to 175F. At idle it was 15.>>>> My oil pressure is well up into the green, even at idle, up in>> the 40s. In flight, it's right where yours is. And my oil temp>> doesn't get to 180F till I've been in the air cruising or climbing>> for maybe 10-15 minutes or more. I think you're there.>>> -- > Dan Yocum> Fermilab 630.840.6509> yocum@fnal.gov, http://fermigrid.fnal.gov> "I fly because it releases my mind from the tyranny of petty things.">>________________________________________________________________________________Date: Tue, 20 Jul 2010 13:46:54 -0500
