Pietenpol-List: Making a trial rib
RE: Pietenpol-List: Re: Pietenpol Directory Update
Sorry Tom, it was a doc. I resaved in all the old versions and added excel.Hope this works.Jack-----Original Message-----
RE: Pietenpol-List: Pietenpol Directory Update
Thanks to those sending back their info. Some had problems opening thefile. I resaved in all the versions of Word and also included an Excelfile. Please don't send info within the email back to me. It's best if youfill out the document and return the file attached. That way it's easierfor me to cut and paste. Well that's about clear as mud.Thanks,Jack_____________________________________________
Original Posted By: CJ Borsuk
I'm surprised nobody mentioned the best reason to makeone or two spare wing ribs when you're assembling them:if you ever ding a wingtip or part of a wing and needto replace a rib, you'll have a pattern that will matchyour other ribs perfectly instead of having to makesomething that is only "close" and not match the others.Of course, you could also keep your rib jig and havethe same effect, but a rib jig doesn't have quite thesame charm as a rib, hanging on your wall.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net _________________________________________________________________The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.http://www.windowslive.com/campaign/the ... __________
Re: Pietenpol-List: Big Piet meets little Piet
> now I have a nice example rib hanging on my wall Bunch of us friends here in MN are building a Piet. When we made the 1st "template"rib, we all signed it. It's hanging somewhere.Kinda cool. :)- Pat--------PatrickXL/650/CorvairN63PZ (reserved)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 20 Jul 2010 13:26:01 -0600Subject: Re: Pietenpol-List: Big Piet meets little Piet
Pietenpol-List: Re: Big Piet meets little Piet
Original Posted By: "Dan P"
Earlier this year, I polled a number of local Pietenpol builders about whetherthey would have fabricated their own metal brackets & fittings, or purchasedthem if they had been available. Based on the information gathered, we've goneahead and made a series of metal kits specifically for the Piet. The kits are substantially complete, and I'm bringing a very large sample set withme to Brodhead. While the samples were made to prints and spec's, they arenot made from 4130, and may not be used in aircraft. That said, the 4130 alloykits will be available in the August timeframe.Because I value the great comments from this forum, I'd appreciate it if any andall of you would stop by to spend a few minutes with me, give me your feedback,and let me know what you think.The completed kits are:1. Empennage2. Jenny Landing Gear 3. One Piece Wing kit4. Center Wing Section of Three Piece Wing5. LH or RH Wing Kit.In addition to the above, we're putting together an engine mount kit, and a controlskit. In the controls kit, there will be dual stick & rudder, along withthe bellcrank behind the pilot's seat.With a few exceptions, all of the parts in the various kits will have all holespre-drilled, and will be pre-bent. In several cases - those spelled out in theplans - the parts will be drilled or bent during assembly.Pricing is being developed as I write this, but suffice it to say, the cost toyou isn't the principal benefit... According to the guys we polled, you mightfind yourself in the air one to two years earlier.I'm personally looking forward to seeing each of you I've met, and those who'veadded so many great comments during the past year.--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Big Piet meets little Piet
As a RC builder and pilot I appreciated the effort. Thanks for sharing. Keepus updated.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 20 Jul 2010 14:13:27 -0700 (PDT)
Original Posted By: John Fay
> To: pietenpol-list(at)matronics.com> > > I see a copy of Fine Woodworking magazine=2C as well as a Bush/Cheney campaign sign. Yep=2C good things should be ahead.> > --------> Mark Chouinard> Finishing up Wings - Working on Center Section> > > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 437#305437> > > > > > > ============================================> > > ________________________________________________________________________________Date: Mon, 19 Jul 2010 11:07:45 -0500Subject: Pietenpol-List: Making a trial rib
