Pietenpol-List: For Sale: Flightcom Classic ANR headset (new in box)
Subject: Pietenpol-List: For Sale: Flightcom Classic ANR headset (new in box)
Re: Pietenpol-List: For Sale: Flightcom Classic ANR headset (new in box)
Subject: Re: Pietenpol-List: For Sale: Flightcom Classic ANR headset (new in box)
Re: Pietenpol-List: latex on sheet metal/fiberglass
Who here has painted their sheet metal/fiberglass components with latex? Andhow did it work for you and what did it look like and how is it holding up. I tried a test panel over some epoxy primer, and even after a month drying,I can still scrape the latex off with my fingernail. I'm wondering if Ineeded to scuff the epoxy primer or use a dedicated latex primer for metal.Douwe________________________________________________________________________________Date: Thu, 2 Dec 2010 10:43:02 -0700Subject: Re: Pietenpol-List: latex on sheet metal/fiberglass
Pietenpol-List: Re: Welding Question
Original Posted By: "Dangerous Dave"
This might be really dumb question but when I'm tack welding parts together thatare bolted to wood structure, for example the landing gear mounts on the bottomlongerons, how do I prevent scorching of the wood or damaging the glue joint?Thanks for the help. This is my first wood airplane.--------Al RiceSkybolt 260RV-9AHelping with my grandson's PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Welding Question
I would build up a dummy of that particular section and tack them up off of that,youwill mess something up if you weld on the fuselage.Dave--------Building a PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Welding Question
That was my first thought -- but it would be a lot of trouble.----- Original Message -----
Dave, I've been having a bit of a problem with E-mails to the Piet list being returned. If this one goes through I guess the problem has been corrected. See you!----- Original Message -----
Re: Pietenpol-List: Welding Question
Subject: Re: Pietenpol-List: Re: Welding Question
Subject: Re: Pietenpol-List: Welding Question
