Pietenpol-List: Dash pix
Re: Pietenpol-List: Re: Mitsubishi Engine ready to get installed...
Original Posted By: Matthew VanDervort
How did you decide that a bearing housing was necessary?Looks like a great idea, but I thought the forged crank and beefy mains on thatengine would handle the prop loads.On Mon, Dec 6, 2010 at 12:48 PM, Chris Rusch wrote:Here is a good shot of my bearing housing, it uses 2 timken bearings.The engine is basically stock except for forged pistons, stainless valves and amild porting job. i also used studs for the main bearing and the head.Read this topic online here:http://forums.matronics.com/viewtopic.p ... omooks.com" target="_blank">www.buildersbooks.comet="_blank">www.homebuilthelp.com="_blank">http://www.matronics.com/contributionle, List Admin.==========st" target="_blank">http://www.matronics.com/Navigator?Piet ... ========-- Ken Chambers512-796-1798 ________________________________________________________________________________
http://www.campbellaeroclassics.com/--- ... tyTamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Dash pix
Pietenpol-List: Re: Dash pix
Jack,PANEL sounds to much like glass...a highly repulsive addition to my 30 yearpassion.I will stick with Steam Dash.dave--------Covering PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 6 Dec 2010 18:23:34 -0800 (PST)
With a radiator only 10" high gives more lifting space on the center wing sectionand using a horizontal flow, high efficiency design by the Brodhead radiatorpeople allows a much smaller cooling system. So far it has excellent possibilities,What would be an objection, other than Bernie's half A radiator doesn't look thesame..Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/radi ... ___Subject: Pietenpol-List: Re: Dash pix
