Pietenpol-List: Do new or rebuilt engines come painted?
Original Posted By: airlion
RE: Pietenpol-List: Do new or rebuilt engines come painted?
You can't tell much from paint. My crankcase is black and my cylinders aregrey but the whole thing I rebuilt a little over 200 hours ago. If the painhas burned off, something has overheated.What kind of engine is it, and how much time does it have on it?Jack PhillipsNX899JP "icarus Plummet"Raleigh, NC _____
RE: Pietenpol-List: Lower motor mount straps
Jack,As others have said, the cross brace contributes little strength in thatarea, as long as it is glued well to the floorbard and firewall plywood.Just cut it to get it out of the way and give yourself room for the fittingand its mounting bolts.Good luck!Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Re: Pietenpol-List: Do new or rebuilt engines come painted?
Original Posted By: r.r.hall(at)cox.net
I once owned a Cessna 150 with a Continental O-200 on which I had to have a major overhaul performed. It came back with a new paint job -- gold case and black cylinders. I don't know if it's common practice but I suspect it is. Don't believe the paint would burn off the case. Incidentally, it would have been better had the push rod tubes been painted white to reflect some of the heat from the cylinders. Chuck ----- Original Message -----
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________________________________________________________________________________Date: Mon, 20 Dec 2010 08:56:02 -0600
Pietenpol-List: Re: Do new or rebuilt engines come painted?
Original Posted By: Woodflier(at)aol.com
Call me ignorant, but why would anyone want to reflect the heat from the cylinders.That would mean sending the heat back to the cylinders. Why would anyonewant to do that?(I'm guessing that I've misunderstood what you were saying)Bill C. Chuck wrote:"Incidentally, it would have been better had the push rod tubes been painted whiteto reflect some of the heat from the cylinders."Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Do new or rebuilt engines come painted?
The ironing is at 250 the new iron wouldn't go hi enough,had to got to the thriftstore for an old one.I drilled in a 5/16 hole in the bow and put in a 1/4"T nut fastened with 3 #4 stainless 1/2" screws.Works great.Took all of 1/2 anhour to fab the stands and it beats doing it any other way.Dave--------Covering PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 20 Dec 2010 09:55:02 -0600Subject: Re: Pietenpol-List: Re: Do new or rebuilt engines come painted?
I guess what I meant was it reflects heat away from the pushrods and associated parts. William Wynne recommends coating the pushrod tubes with white paint -- I've forgotten why but he's the engine guru.----- Original Message -----
Bill, Ryan said it better that I did. I don't know from small Continentals----- Original Message -----
Okay, I get it. The reflecting you're referring to is AWAY from the pushrod tubes,not necessarily back at the cylinders (even though that's where some of itwill go). So, paint the pushrod tubes white IF you're using a Corvair.I know I've read about oil temperature issues with some Corvair installations,so probably every little bit should help. Never heard of this idea for Continentals,though. Like Ryan says, the configurations are different, with more clearanceon the Continentals.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Do new or rebuilt engines come painted?
Not necessary on real aircraft engines. Corvairs require all the help theycan get.
-----Original Message-----
