I have installed full length piano hinge for the ailerons. Now when I go toinstall the aileron horn the top bolt would exit through the hinge flange.For those who have installed piano hinges, how did you deal with the upperbolt and the hinge interference. Here are my options as I see it:1: Recess the bolt head into the aileron spar so the hinge could sit flatbut I don't know if that is ok. 2: Moving the top hole down about a half inch but that would reduce thespacing between the two holes and I'm guessing make the aileron horn moresusceptible the twisting.3: Notch the aileron hinge flange to clear the bolt head. To me #3 sounds like the best idea but I just don't know. ChrisSacramento, CaWestcoastpiet.com________________________________________________________________________________
Pietenpol-List: Aileron Horn and Piano Hinge
RE: Pietenpol-List: Aileron Horn and Piano Hinge
Chris it was 3 for me. Also had to re-make aileron pulley brackets as youcan see here. Rear horn brace was not installed yet either.JackDSM-----Original Message-----
I think I did the same as Jack did.Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC-----Original Message-----
Re: Pietenpol-List: Aileron Horn and Piano Hinge
Subject: Pietenpol-List: Mike Cuy DVD back in productionFor some of you who were asking about my 2.5 hour 'The Building and Flying of NX48MC' DVD I am now back in production(after my old DVD recorder decided to freeze up, not finalize and a myriad of other problems which I won't bore you with)and the DVD can be obtained for $25 which included Priority Mail shipping to PO Box 736, Berea, OH 44017. Checks, cash, moneyorders firstborns, no paypal, any international orders must be checks in US funds and the check must have a bank name affiliated with the USA printedon it.Thank you,Mike C.________________________________________________________________________________Date: Tue, 25 Jan 2011 08:11:03 -0700Subject: Re: Pietenpol-List: Aileron Horn and Piano Hinge
Original Posted By: at7000ft(at)gmail.com
for what it is worth=2C I took option 1 and recessed the bolt. I used a structural-type countersunk screw and large diameter dimpled washer. It fits flush under the hinge just fine.GeneDate: Tue=2C 25 Jan 2011 08:11:03 -0700Subject: Re: Pietenpol-List: Aileron Horn and Piano Hinge
