When you attach the 2 tail brace cables to the top v-stab bracket, is itacceptable to just use a thimble?Thanks,JackDSM________________________________________________________________________________Date: Wed, 9 Mar 2011 12:56:30 -0600 (GMT-06:00)
Pietenpol-List: V-Stab Fittings
Pietenpol-List: Re: Props and hub and progress
Original Posted By: "K5YAC"
So my 4 bolt prop hub came in the mail today from Ken P...it looks great... andi got Dans prop carving CD with the last Aircraft Spruce order and now i canhardly wait to put the two together and make sawdust.My engine is almost done... the short block anyway and should be coming from antiqueengine up by chicago..cut out and formed both aileron horns and welded one up before i had to go outof town last week.... not as hard as i thought.. looks good and is strong forsurecut out my ailerons last week too.. a few more brackets and i can mount the wingman i can't wait to fly this thingjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Props and hub and progress
Original Posted By: "bender"
Sounds cool... and that's a great N-number.What is this? Looks mean! --------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Props and hub and progress
its a Ragwing Special.... i built it about 12 years ago... wood and fabric.. likebuilding the piet but with aluminum fittings that were all bolted and simple...it was fun to fly..but i made the mistake of using a two stroke and nevertrusted it after the one time it quit on me.... luckily i was on a tight downwindi've thought of building another one with a better enginejeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: V-Stab Fittings
Ken,I was wondering if you still have that source available for a Corvair engine ortwo that might be available. I'm interested. For that matter, anyone else inMinnesota that might know of a guy with an engine available for purchase andre-build, I'd be interested. None of the local salvage places seem to have any.I suspect there are a lot more engines kept/hidden in barns and storage shedsaround here than you'll find on e-bay or on Craig's list. Any help wouldbe appreciated.TomRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: V-Stab Fittings
My spring is about 2/3 of a dirt bike rear coil spring. I cut it off and groundthe end smooth. Works for me. Price was right.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Thanks for the information,That is a nice looking little bird.I used to follow a ragwing forum but it got too nasty, and too much misinformation.That is what I like about this group. Much more professional.--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: V-Stab Fittings
