Pietenpol-List: Milestone
Subject: Pietenpol-List: MilestoneIn a message dated 9/24/03 11:20:35 AM Central Daylight Time, jim_markle(at)mindspring.com writes:.....wooohoooo!!!!!! HUGE MILESTONE!!!!! >>Hey Jim,I love hearing about all these milestones !! However, your link didn't work...it just sent me to the home page. Oh, er, maybe you didn't notice the plans...there is NO dihedral in a Pietenpol ;)I think maybe Mike Cuy overlooked this also...Chuck G.just trying to stir it up________________________________________________________________________________
Re: Pietenpol-List: Milestone
Dihedral, schmihedral! I'll have a bit of washout too!!! SO THERE!!!! :-)Somehow I included "woohoo" in the link....so just delete the part after"Log>" and it should work. Worked fine on mine but maybe my system is soused to "woohoo's" and such silliness that it just tolerates me and moveson.....Try this:I should probably spare everyone TONIGHT'S milestone.....I probably should but I won't........so here it is: BOTH left side sparsbolted on at the root, propped up on the ends with two ribs slid on and somestring drag wires (or whatever those X brace wire thingys are called).....itlooks really cool.....I've written about 15 different descriptions of how wonderful this is andnothing really describes it.......if you've done it, you'll know. If youhaven't yet, you're going to be amazed......Jim in Plano----- Original Message -----
Pietenpol-List:
Hello,]New member to your discussion group here. My first question is... Where wouldyou guys recommends I go for Model A gauges; tach, water temp, oil temp etc. Andwhat kinds have worked for you. I'd love to find some modern mechanical gaugeswith a vintage look, but so many new suppliers are only making electric gauges.Any thoughts? Also, know anyone who wants to make a Piet radiator?Douwe________________________________________________________________________________
Subject: Re: Pietenpol-List: MilestoneIn a message dated 9/24/03 11:25:43 PM Central Daylight Time, jim_markle(at)mindspring.com writes:>Jim,I checked out your shutterfly album. I need to do that with mine, too. It's a really good way to scan thru the progress. Lookin' good !! Oh, by the way, there is no dihedral, or washout in the Pietenpol plans, or any of the planes that BHP built. There is no dihedral or washout in the Tailwind, either. Wonder why these two Guru's of aircraft design chose not touse it...maybe it's because bent and twisted wings are for sissy's !!! :)Chuck G.________________________________________________________________________________
Original Posted By: Jim Boyer
Got the gear fitted and welded. A big thank you to Jerry Grogan forassisting with the welding. Starting to re-spoke the rebuilt wheels, lifeis good. Jack TextorDSMNX1929T________________________________________________________________________________Date: Thu, 28 Jun 2012 01:28:03 +0000 (UTC)
RE: Pietenpol-List: Milestone
Looking good, Jack!Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Pietenpol-List: Re: Milestone
Jack, its a pleasure to see your job, I have't seen work as neat as yours.Regards--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Congrats Jack.....Nothing prettier than a nicely laid weld bead.
Original Posted By: Dan Yocum
Super-Duper Jack! A Sig Kadet would have been my guess too. Never owned one, but have built andflown many others. I guess it's the large wing tip angles that make it seem right...I believe that the Kadet has been around since before I started in thehobby in the 80s. Heck, even your R/C stuff looks great!--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Milestone
