As tools mentioned, more specific info would be good. The repair method wouldprobably depend on the size, extent and location of the damage. Is it merelya surface crack, an obvious break or a complete hole in the plywood? How accessibleis the underside of the damaged area? It could be as simple as applyinga thin doubler patch to the underside, or it could be as extensive as replacingthe entire damaged area with new plywood. As also noted by Jack P, referto AC 43.13 for the procedures and standards to effect such repairs.--------Billy McCaskillBaker, LAtail section almost done, starting on ribs soonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Can someone explain why...
Gary, Which airport are you taking it to?--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Can someone explain why...
