Pietenpol-List: 3 piece wing 1 wing weight
Subject: Re: RE: Pietenpol-List: Re: Wire?Mario Giacummo. -..- .. ... - .. .-. / . ... / ..- -. / .... . -.-. .... --- --..-- /...- .. ...- .. .-. / . ... / ..- -. / .- .-. - .2012/12/18 Gardiner >>________________________________________________________________________________Subject: Pietenpol-List: 3 piece wing 1 wing weight
Pietenpol-List: Re: 3 piece wing 1 wing weight
Hi, just curiosity; which is the weight of a wing? finished and covered or notI want to check mine.... regards.--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: 3 piece wing 1 wing weight
Mario: you are in luck! I have the wings off of my airplane and it will be fairlyeasy to weigh them. The right and left wings are almost identical exceptone has the tubing for the pitot tube (airspeed indicator) inside it. They arecovered and painted and have all metal fittings attached and aileron cablesinstalled.The only way that I can weigh them is with bathroom scales. I have two digitalbathroom scales in the hangar so they will not be exact, but I may try to checkthem with something of a known weight (like a concrete test cylinder), thenI will weigh them and post the results here. I probably will not have a chanceto do it until Saturday.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: 3 piece wing 1 wing weight
Hello Oscar... allways you giving hands :0)It just for curiosity, just to feel comfortable with the job. I weight (como sedice en pasao?) the folowing finished parts without cables:fixed part of rudder : 0.9 kthe two elevators : 1.7 k each onetomorrow I am going to weigh the wing and add the others parts of the empanajeHave a good day--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 19 Dec 2012 08:24:21 -0600
Re: Pietenpol-List: Re: 3 piece wing 1 wing weight
Original Posted By: Jim Boyer
Mario,Will weigh wing for you this weekend.CheersGreg BaconNX114DOn Dec 19, 2012, at 4:53 AM, "giacummo" wrote:> > Hello Oscar... allways you giving hands :0)> It just for curiosity, just to feel comfortable with the job. I weight (comose dice en pasao?) the folowing finished parts without cables:> > fixed part of rudder : 0.9 k> the two elevators : 1.7 k each one> > tomorrow I am going to weigh the wing and add the others parts of the empanaje> > Have a good day> > --------> Mario Giacummo> http://vgmk1.blogspot.com> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 682#390682> > > > > > > > > > ________________________________________________________________________________Date: Wed, 19 Dec 2012 18:56:49 +0000 (UTC)
ok, mine is around 34 kg (75 lbs) left wing....--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 19 Dec 2012 16:04:10 -0600Subject: Re: Pietenpol-List: Re: 3 piece wing 1 wing weight
no, it is not painted, just ready to cover.but I think I did the things wrong, this weekend I am going to weiht it again--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: 3 piece wing 1 wing weight
Jerry, I use douglas fir; did you too?... (I forgot talk about the used wood).I can thin evrything is ok by the moment.. salu2--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: 3 piece wing 1 wing weight
Re: Pietenpol-List: 3 piece wing 1 wing weight
Subject: Re: Pietenpol-List: 3 piece wing 1 wing weight
Greg, does your center section have a fuel tank? If so, what is it made of? It won't be too long before I'll be ready to cover and paint and can't decide on a center section tank or one in the front seat compartment. Chuck ----- Original Message -----
