Original Posted By: Jack
Me again...looking for the correct bolts to secure the box to the carb. Not AN3, 1/4x20 thread ok but seem a bit loose. Any ideas?ThanksSent from my iPadJack Textorle, List Admin.________________________________________________________________________________Subject: Re: Pietenpol-List: Airbox Question 2
Pietenpol-List: Re: Airbox Question 2
Me again...looking for the correct bolts to secure the box to the carb. Not AN3, 1/4x20 thread ok but seem a bit loose. Any ideas?ThanksSent from="http://www.matronics.com/contribution" target=_blank>http://www.matro- - - - - - - - - - -Mattonics.com/Navigator?Pietenpol-List" target=_blank>http://www.matronics.co==========3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D________________________________________________________________________________Subject: Pietenpol-List: Re: Airbox Question 2
That makes sense Shad, will have to dig up some studs, thanks!Sent from my iPadJack TextorOn Jan 1, 2013, at 3:58 PM, shad bell wrote:I can check my 65 on the baby lakes, but I think they are studs, not bolts, the threads in the bottom of the carb are 1/4 20, but I believe the threads in the bottom (for the castle nuts)-are 1/4 28 with a drilled shank for a castle nut and cotterpin.- Like I said I am not certin so I can check.-Shad--- On Tue, 1/1/13, Jack wrote:
Also, looks like I will need to fab the support bracket that secures the box tothe case....Sent from my iPadJack TextorOn Jan 1, 2013, at 1:25 PM, Jack wrote:> > Thanks JP, Oscar and Shad! Think I will try the plate nuts. Got a bunch doneon the Piet this Holiday break. Lots of sanding, finished up panel except finalfinish and radio, got the firewall started and finished my motor mount jig finishedand painted. Next stop will be the engine mount.> Safe New Year to all!> > Sent from my iPad> Jack Textor> > On Dec 31, 2012, at 1:08 PM, Jack wrote:> >> >> Checked the manual and it appears instead of plate nuts they specify some kindof locking zeus fastener. Would bolts and plate nuts work also?>> >> Sent from my iPad>> Jack Textor>> >> On Dec 31, 2012, at 12:41 PM, Jack wrote:>> >>> >>> For my C85 I need to rivet ms21047-L3 plate nuts (10-32) to the box to holdthe filter. Do I need drilled an3's to secure the filter with safety wire orwill the plate nuts suffice like lock nuts? Also, I assume I need a gasket betweenthe airbox and carb. Is there a gasket between the filter and airbox?>>> Thanks and Happy New Year!>>> >>> Sent from my iPad>>> Jack Textor>> >> >> >> >> > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Airbox Question 2
Me again...looking for the correct bolts to secure the box to the carb. Not AN3,1/4x20 thread ok but seem a bit loose. Any ideas?ThanksSent from my iPadJack Textor________________________________________________________________________________Date: Tue, 1 Jan 2013 13:58:07 -0800 (PST)
Original Posted By:> Jack
That makes sense Shad, will have to dig up some studs, thanks!Sent from my iPadJack TextorOn Jan 1, 2013, at 3:58 PM, shad bell wrote:> > I can check my 65 on the baby lakes, but I think they are studs, not bolts, the threads in the bottom of the carb are 1/4 20, but I believe the threads in the bottom (for the castle nuts) are 1/4 28 with a drilled shank for a castle nut and cotterpin. Like I said I am not certin so I can check.> > Shad> > --- On Tue, 1/1/13, Jack wrote:>
Original Posted By: "Allan Macklem"
Hybrid studs for an application like this seems odd.Sounds like the carb has 1/4-20 threaded holes, so using 1/4-20 studs seem to makesense.I did a little internet search, and found this link to a Continental parts manual:http://rob.com/matt/manuals/O-200_Parts_manual.pdfOn pages 28 and 29, the relevant components are shown (scan attached), and thestuds (index no. 28 ) are identified as "Stud, Plain, 1/4 x 7/8 Inch long". Theassociated nut (index no. 29 ) is identified as "Nut, Plain, Hex 1/4-28.So, based on this info, the hybrid studs probably are what was used. But who knowswhy. I can't see why it wouldn't be fine to just use 1/4-20 studs, and sometype of locking nut.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/c85_ ... __________
Re: Pietenpol-List: Re: Airbox Question 2
As a former USAF officer (non-rated) I am completely humbled by thisofficer's account. It's in MS Word so I hope the photos will transmit.Allan Macklem________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Airbox Question 2
Bill thanks so much for your usual excellent research! I found the same info butmy manual wasn't as clear as yours, thanks!Sent from my iPadJack TextorOn Jan 2, 2013, at 3:57 PM, "Bill Church" wrote:> > Hybrid studs for an application like this seems odd.> Sounds like the carb has 1/4-20 threaded holes, so using 1/4-20 studs seem tomake sense.> I did a little internet search, and found this link to a Continental parts manual:> http://rob.com/matt/manuals/O-200_Parts_manual.pdf> On pages 28 and 29, the relevant components are shown (scan attached), and thestuds (index no. 28 ) are identified as "Stud, Plain, 1/4 x 7/8 Inch long".The associated nut (index no. 29 ) is identified as "Nut, Plain, Hex 1/4-28.> So, based on this info, the hybrid studs probably are what was used. But whoknows why. I can't see why it wouldn't be fine to just use 1/4-20 studs, andsome type of locking nut.> > Bill C.> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 485#391485> > > > > Attachments: > > http://forums.matronics.com//files/c85_ ... ox_128.pdf> > > > > > > ________________________________________________________________________________Date: Wed, 2 Jan 2013 18:06:59 -0800 (PST)
I think the question is why was course threadused on the engine side? Is it, as I suspect,that course threads are stronger in the softcase material? I'll bet that having fine thread on the other endisn't so av nuts could be used but that aviationnuts would go nuts trying to figure out whysome acorn would throw a brazil in the works!ClifAs we acquire more knowledge, thingsdo not become more comprehensible,but more mysterious. Albert Schweitzer.Hmmm....promises to be an interesting year
----- Original Message -----
