Keep it simple 5052 x .050 tig weld--------Adrian MWinnipeg, MBCanadaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/dsc0 ... ___Subject: Pietenpol-List: Model A with carb heat box
Re: Pietenpol-List: Model A with carb heat box
Does anyone have data or anecdotal information on how much extra RPM one gets by shutting off the "perpetual" carburetor heated air on a model A?Dan HelsperPuryear, TN________________________________________________________________________________Subject: Re: Pietenpol-List: Model A with carb heat box
Doesn't the RPM go to zero when you turn off the carb heat on a Model A?:o)Dan-- Dan Yocumyocum137(at)gmail.comOn Jan 16, 2013, at 7:25 AM, helspersew(at)aol.com wrote:> Does anyone have data or anecdotal information on how much extra RPM one gets by shutting off the "perpetual" carburetor heated air on a model A?> > Dan Helsper> Puryear, TN> ________________________________________________________________________________Subject: Re: Pietenpol-List: Model A with carb heat box
Original Posted By: Dan Yocum
I have a special gauge on my engine that indicates when I can turn off the carb heat.......when the condensation finally dries-up....stops slinging-off the induction and hitting me in the face! BTW I knew you were still "here" D.Y. I could feel it :O)Dan HelsperPuryear, TN-----Original Message-----
Pietenpol-List: Re: Model A with carb heat box
I forgot to add-Tools, nice comments.Dave, It sounds you have decades of experience in airplane construction and know howto make good choices. I would be happy to talk with you about your steel tubefuselage. Either online or offline. This is a good resource for Pietenpols ingeneral, but. as Tools said, not too many steel tube fuselages in the group. Ihave a steel tube fuselage I purchased about a year ago, and I have many questionsthat you, or pictures of your Pietenpol might answer.Let me know the easiest way to get with you. Also, thank you for your service,but don't let Tools fool you. Not only is he an 'old tanker pilot', but he didit in "Hoovers"! For any non-Naval Aviation types, that is the S-3. Listen toone start up and you know why they are called "Hoovers".--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Model A with carb heat box
