Pietenpol-List: TRANSPONDER MOUNT
Original Posted By: "Barnwell Regional Airport"
Subject: Pietenpol-List: TRANSPONDER MOUNTEVERYONE HAS A DIFFERENT WAY OF DOING THINGS. MY TRANSPONDER MOUNTING. I HAVE AN ALUMINUM COVER OVER MY FUEL TANK AND THE KT76 ANTENNA IS MOUNTED TO ITTED STONE________________________________________________________________________________
Pietenpol-List: Re: Comparison test between Pietenpol airfoil and Riblett
Fellow Pietenpoler's,For some time, Don Harper and I had planned to write up the results of a "head to head" test comparing the Pietenpol airfoil to the Riblett airfoil. To the best of our knowledge, no one else has conducted the same type testing. The write up is self explanatory as to our methods. Remember, testing is ongoing and will continue. The various numbers you see now very likely will change as we do further testing. Updated results will be posted when we have something worthwhile to add..Our intend, is to share the information with the Piet community, not to start an argument. thank you,P. F. BeckDon HarperBarnwell, S. C.________________________________________________________________________________Subject: Pietenpol-List: Re: Comparison test between Pietenpol airfoil and Riblettairfoi
Re: Pietenpol-List: TRANSPONDER MOUNT
Subject: Re: Pietenpol-List: TRANSPONDER MOUNTTHE CENTER SECTION IS ON SAW HORSES UP SIDE DOWN AS YOU CAN SEE THE CABINE ATTACH BRACKETS THERE ALSO. ON THE TRANSPONDERS THE CONTROL KNOB IS ON THE LEFT HAND SIDE.IF YOU LOOK CLOSELY YOU WILL REALIZE THAT I AM CORRECT.NO I WON'T ANY TROUBLE READING THE UNIT. I'LL POST PIC TURES LATER SHOWING RIGHT SIDE UP.TEDIn a message dated 1/25/2013 12:51:35 P.M. Eastern Standard Time, TOMS(at)mcpcity.com writes:--> Pietenpol-List message posted by: "TOM STINEMETZE" I hate to mention this Ted, but unless you are dyslexic in the vertical dimension, you are going to have problems reading the dials on that thing. 8^]Stinemetzedo not archive>>> 1/25/2013 11:10 AM >>>EVERYONE HAS A DIFFERENT WAY OF DOING THINGS. MY TRANSPONDER MOUNTING. I HAVE AN ALUMINUM COVER OVER MY FUEL TANK AND THE KT76 ANTENNA IS MOUNTED TO ITTED STONE________________________________________________________________________________Date: Fri, 25 Jan 2013 14:59:32 -0600
Re: Pietenpol-List: Comparison test between Pietenpol airfoil and Riblett
Original Posted By: Jack
TomA really neat Unit is from TRIG. The encoder is built in, it's low current drainage,small and lightweight. It's also Mode S.Take a look. http://www.aircraftspruce.com/catalog/a ... ___Subject: Re: Pietenpol-List: Comparison test between Pietenpol airfoil and Riblettairfoil
Original Posted By: TGSTONE236(at)aol.com
Beautiful ships!Sent from my iPadJack TextorOn Jan 25, 2013, at 1:56 PM, "Barnwell Regional Airport" wrote:> Fellow Pietenpoler's,> > For some time, Don Harper and I had planned to write up the results of a "head to head" test comparing the Pietenpol airfoil to the Riblett airfoil. To the best of our knowledge, no one else has conducted the same type testing. > > The write up is self explanatory as to our methods.> > Remember, testing is ongoing and will continue. The various numbers you see now very likely will change as we do further testing. Updated results will be posted when we have something worthwhile to add..> > Our intend, is to share the information with the Piet community, not to start an argument.> > thank you,> > P. F. Beck> Don Harper> Barnwell, S. C.> > > > ________________________________________________________________________________
Subject: Pietenpol-List: TRANSPONDERKEN, THE REASON I LEAVE THE CAP LOCK DOWN IS I HUNT AHD PECK TYPING MAKING IT EASIER FOR ME SOME OF US OLD(75) FOLKS NEVER TOOK TYPING OR KEYBOARD IF THAT IS POLITICALLY CORRECT.TOM, I HAD THIS KT76 FOR YEARS IN MY BEECH A-23.AN A&P BUDDY AND I WENT THROUGH MY PLANE YEARS AGO FROM A TO Z. THE KT 76 WOULD NOT TRANSMIT. I ORDERED A GARMIN 320 FOR IT.WHEN STARTED TO CONVERT WE FOUND THE ANTENNA UNPLUGED. NOT WANTING THE WIFE TO KNOW, WE INSTALLED THE NEW UNIT AND KEPT QUIET ABOUT IT.THAT IS MY REASON FOR THE KT 76.IT IS BEST SOMETIMES WHAQT GOES ON IN THE HANGER STAYS IN THE HANGER.TEDBUILDING CORVAIR POWERED WITH DAN'S 5TH BEARING________________________________________________________________________________
