Original Posted By: markmckellar(at)reagan.com
I'll be using a Lamina H-56 spring as recommended by others. It is a 6" die spring...you can find more information in this catalog (see link)... look in theGold series spring section for H-56.http://www.elsimeth.com/priv_prods_pdf/ ... talog.pdfI got mine from H&O Die Supply in Kennedale, TX (1-800-222-5441) for $18.75 each.--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 6 Feb 2013 22:46:24 -0600 (CST)Subject: Pietenpol-List: landing gear
Pietenpol-List: Re: landing gear
I've attached the notes that I am using. I'm not sure where I got this page (probablyMarkle), but it appears to be from the Buckeye newsletter. The H-56 springis called out here, which is still available for a reasonable cost.--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/land ... ___Subject: Pietenpol-List: Re: landing gear
Oscar beat me to it, but here is a link to the full article on William Wynne'swebsite FlyCorvair.net-[/u]--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 07 Feb 2013 08:17:06 -0600
RE: Pietenpol-List: landing gear
Original Posted By:sand in Chuck Norris=92 face=85 Gary BootheNX308MB owner-pietenpol-li
Oooo=85A Sky-camper! You take advantage of the fact that TC has left the building=2C although I=92m sure this is merely the Sunday morning musings of an idle mind. Joe ' Please explain yourself before you invoke the wrath of his deputy=2C Safety Dan! I suspect that this falls into the category of =91some things you just don=92t do=92=2C like pee into the wind=2C or kick
