Pietenpol-List: BFR review
Subject: Pietenpol-List: George in AustraliaGeorge-are you on the island of Tasmania? That is where good friend and Piet builder Simon McCormack and familylive. Simon has a gorgeous red and cream Ford Piet. He and his wife Susan are making the trip to Brodhead and Oshkoshfor the very first time this summer! I've been pen pals with Simon since around 1994 and really looking forward to seeinghim and watch his face when he finally sees what Brodhead and Oshkosh are really like.Mike C.________________________________________________________________________________Subject: Pietenpol-List: BFR review
Re: Pietenpol-List: BFR review
Original Posted By: Jack
Got my BFR scheduled for tomorrow, and was roaming YouTube vids for some review. Clicked on Martha King segment. Gosh Mikey, you are all over!! http://youtu.be/40Ac2YD2LNsDan HelsperPuryear, TNDan HelsperPuryear, TN________________________________________________________________________________Subject: Re: Pietenpol-List: BFR review
Jeez Mike hope you are getting royalties!Sent from my iPadJack TextorOn Feb 21, 2013, at 6:14 PM, helspersew(at)aol.com wrote:> Got my BFR scheduled for tomorrow, and was roaming YouTube vids for some review. Clicked on Martha King segment. Gosh Mikey, you are all over!! http://youtu.be/40Ac2YD2LNs> > Dan Helsper> Puryear, TN> > ============================================================================================================================================> ________________________________________________________________________________
RE: Pietenpol-List: BFR review
.so now you're ready?Gary BootheNX308MB
Original Posted By: Tim White
Subject: Pietenpol-List: BFR reviewMartha King really got to me in that video Gary. How dare she stand in front of that nice video EAA took of mewhile I was lost over the Hurricane Wood.Mike C.http://www.youtube.com/watch?v=40Ac2YD2 ... ______Date: Fri, 22 Feb 2013 12:40:41 -0500
Subject: Pietenpol-List: motor mounts available herehttp://www.cozygirrrl.com/aircraftparts.htmThey will make them longer than standard length if you want, just specify.It only took me about 2 hours to make a motor mount jig. You can build offset into it as well.Mike C.[cid:image001.jpg(at)01CE110B.93346500]________________________________________________________________________________Subject: Re: Pietenpol-List: BFR review
Original Posted By: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] (GRC-RXD0)[Vantage
Maybe the Hurtgen Wood?Dan HelsperPuryear, TN-----Original Message-----
Re: Pietenpol-List: motor mounts available here
Subject: Re: Pietenpol-List: motor mounts available hereWe invested a lot of time in the jig in order to make it adjustable.It can accommodate different firewall widths and distances from the firewall.Chrissi & Randi_www.CozyGirrrl.com_ (http://www.cozygirrrl.com/) ClickBonds 10/$7.50CG Products, Custom Aircraft HardwareChairwomen, Sun-N-Fun Engine WorkshopIn a message dated 2/22/2013 1:48:52 P.M. Central Standard Time, michael.d.cuy(at)nasa.gov writes:_http://www.cozygirrrl.com/aircraftparts.htm_ (http://www.cozygirrrl.com/aircraftparts.htm) They will make them longer than standard length if you want, just specify. It only took me about 2 hours to make a motor mount jig. You can build offset into it as well. Mike C. ________________________________________________________________________________
Subject: RE: Pietenpol-List: BFR reviewAha---some good WWI facts there Dan. I always thought it was Hurricane Wood.Well actually it was over New Holstein. The New Holstein wood but thanks to you I know knowwhere Redford said he was flying!
Pietenpol-List: Re: BFR review
Nice idea posting some of the basics like this... I am not only building the dreadedRiblett airfoil, I'm building the FATTER one, the Riblett GA-30-613.5 version(as Harry Riblett would continue to correct me as we discussed the airfoilon the phone one day...).I cut a profile of the modified airfoil with an exaggerated bend on the top andbottom of the airfoil with a CNC machine, and put some holes in it for pins tobe placed that held the bungie cord "clamps" I used. (Pictures if I get a chance...).Here's the "high-tech", harder than it has to be (but I did it anyway and that'swhy it's taking me years to build the plane") method I used for soaking thecap strips on the ribs I have so far:I built a soaking tube out of PVC pipe, capped on end, and put a slip cap on theother with a vacuum tube fitting on it. I put an "o" ring in the cap and filledthe tube 1/2 way with water. Dropped 6-8 capstrips in, sealed the tube andflipped on the vacuum pump for an hour or so. Pressure sucked the water intothe wood a bit more than just soaking, and I haven't had a strip crack yet puttingit on the bending jig.But, a bathtub, hot tub, or just soaking it overnight is easier and works as wellI think. But the steam kettle-PVC system looks cool!My .02....MarkRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: BFR review
Original Posted By: "Jack"
You know Mike, you outta get the award for "best ambassador of Pietenpol's" inshort clip movies, but I am not sure the Academy grants such an award. Perhapswe can suggest one?Regardless, how nice it must be to have such a recognizable representation of aniconic plane. And, to have helped so many follow suit!MarkRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: BFR review
Oh, Mark...don't encourage him! Can you imagine what he would wear to walkdown that red carpet?!Gary BootheNX308MB-----Original Message-----
