Original Posted By: "pineymb"
IIRC, 16 in a squadron?DaveRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Baggage Cage
Pietenpol-List: Re: Baggage Cage
I really need to fly soon so i can get the 40 hrs off by then.I had a couple of emails with Jim... and Bob McKinley is the guy across the riverat JVY i believe... I've seen his plane in the hangar over there.Can't wait for that trip northi have a smaller diameter crankshaft pulley on the way to slow down the water pump...Hope that solves my issue so i can get off the groundjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Baggage Cage
Now see, I like that cage too! Great idea! A guy could even make it out of aluminumand pop it all together with pulled rivets and not need to weld anything. We don't need no FAA, PMA, STCs, 337s, or any of that other stuff, either;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Successful gross weight test
Today, "RE-PIET" successfully carried her max gross weight. As I considerit unsafe to try to secure 160 of ballast in the cockpit, I decided to usemyself.All went well. Obviously a bit more sluggish, but trimmed out and stallednicely. This load was 40 lbs more than Marci and I with a full load of 20gallons.Douwe________________________________________________________________________________Date: Sun, 21 Apr 2013 18:32:06 -0600Subject: Re: Pietenpol-List: Successful gross weight test
Pietenpol-List: Re: Successful gross weight test
What was your stall speed whilst at gross?Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
