Pietenpol-List: Telegram
FYIRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/tele ... __________
RE: Pietenpol-List: Telegram
Original Posted By: Craig Aho
Subject: RE: Pietenpol-List: TelegramWay to go Bill---you're going to love it even more once you have your first flight!Love the old-fashionedtelegram message!Mike C.________________________________________________________________________________
Original Posted By:> billsayre(at)ymail.com
Wow another neighbor with a Pietenpol. I look forward to hearing all about it. Craig > Subject: Pietenpol-List: Telegram
The CAA hasn't made it to California yet. Very nice, Bill!!!Gary BootheNX308MB-----Original Message-----
Pietenpol-List: Re: Telegram
Being a bit short torso'd,well, maybe short all over.I was 5' 8 1/2" when younger but now seem tohave lost an inch of that somehow. Anyway,thismeans that my shoulders don't stick up abovethe turtle deck. THAT means my shoulderharness can safely route through the top edge ofthe seat back. I have cabled the two straps intoone that goes back to the tail post. The rod thatfits is 12" dia 6061-T6 alum. The black bits on thetail rod are rubber tube lengths to keep the cablecentered.If you need them higher and also don't want to cutinto the back then possibly my first idea mightgive you a start. That's the drawing. The bumpswere going to be fabric covered balsa.Clif> I've seen several Piets and they do NOT have shoulder harnesses - just > seat belts. Does anyone use a 4-point harness in the back seat or is it > tradition to use only a lap belt?since the seat back is built-in to the frame - there will have to be some serious wood cutting to install the shoulder harness..> Jim McWhorter> N687MB (New Owner)> Culpeper, VA KCJR________________________________________________________________________________Subject: Pietenpol-List: Re: Telegram
Jim,I see you have two (VNE) speeds. I think the 100 MPH should be the correct one.You may want to do your own testing to see if all the different numbers domatch your planes performance. What better way to learn about your new plane.Have fun flying and wear that open cockpit smile with pride.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Telegram
Original Posted By: Andre Abreu
Congratulation Bill, What a great feeling when you get the signed docs saying you can fly it. Now gomake an airplane out of it and fly.Happy Landings,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 26 Apr 2013 05:39:47 -0700 (PDT)
Re: Pietenpol-List: Ruddder Horn Repair
Original Posted By:> Jack
It worked thanks AndySent from my iPadJack TextorOn Apr 26, 2013, at 7:39 AM, Andre Abreu wrote:> Thanks for letting me know. The permissions on Picasa were not set correctly. > Everyone should be able to see these photos of the rudder horn failure now.> > Best Regards,> Andy Abreu> KTDZ > >
No, the training industry. For 30 plus years I have been involved with Dale CarnegieTraining as an instructor and sales rep. There is an opportunity in Beaumontthat I am investigating.ABC: ANYWHERE but California.So, if I do move there, I'm wondering how many Pieters there are to co-mingle with...:o)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Telegram
Original Posted By: "Dick N"
Well Done! Love the telegram look too!Post pictures for us land lubbers.MarkRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Thanks all.gboothe wrote:> The CAA hasn't made it to California yet. Very nice, Bill!!!> > Gary Boothe> NX308MB--Might want to post a couple of people watching the road leading to the airportGary - last I heard, Newt was heading that direction to see about some event.Mark - here's the most current picture I have (just after assembly after painting).First taxi can be seen at http://www.youtube.com/watch?v=_bI6tOxN ... ndex=1Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/cove ... __________
Original Posted By: "BYD"
> > > Yes. I had oxy-acetylene welded the pin into the axle, and probably had a> small crack there which caused enough of a stress concentration to weaken> the axle. But after it broke and I (belatedly) ran a stress analysis onthe> design I was surprised to see how highly loaded that configurtion is and> concluded that it was a very marginal design. > > On my new axle I had a professional welder TIG weld the pins, then sentthe> whole assembly to Rex Heat Treating in Pennsylvania to be heat treated to> 160,000 psi (normalized 4130 is good for 90,000 psi). Of course heat> treating does not increase stiffness, so it still has a slight bow butnot> apparent to the eye (as Jerry Dotson said, you can see the bow with a> straightedge). The bow is significatnly less than it was with the .120"> wall.> > Jack Phillips> NX899JP> Smith Mountain Lake, Virginia> > ----------NX321LRFully AssembledTail assembly and ailerons covered and painted.Wings covered and primed, one paintedMitsubishi PoweredRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Telegram
