Pietenpol-List: N1929F Flight
Original Posted By: "bender"
I must have just missed you last night John! I left shortly after you landed therough running one, I had to run up to Moraine to take care of an ELT batteryfor a guy. But Congrats!!! and be glad you don't have to wear the silly uniform....Bob, what days are you usually up there at MGY?--------www.vansaviation.com follow my Piet rebuild there!almost dissasembled, getting ready to order all AN hardware and SS cableRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: N1929F Flight
Pietenpol-List: Re: N1929F Flight
Original Posted By: "BYD"
not great quality but here is a video of the first takeoffwife commentary and all...http://www.youtube.com/watch?v=zlesP2y0cKMI had some water coming out of the overflow at first, climbing.I hear that's kinda normal... but it got a bit hot.. my radiator is small 19" tallx 8" wide two row aluminum, I was hoping it was enough... now I think not.I believe the Lovely radiators are 20x12 ?? I'm gonna go bigger.The airplane itself felt OK.. off the ground quick.. ailerons are just as advertised.. a little slow.. elevator a little sensitive..but nothing weird at all.that was funjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: N1929F Flight
Original Posted By: "VanDy"
FANTASTIC!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: N1929F Flight
And you guys from down south, make sure towear your heavy winter coats. Theres an instanttemperature shear at the 49th parallel.ClifQ: Are there supermarkets in Toronto and is milk available all year round? ( Germany )A: No, we are a peaceful civilization of Vegan hunter/gatherers. Milk is illegal.> >> Of all the luck...>> On the other hand, you could still drive. Google maps says it would only > be a 37 hour drive (each way) for you, Gary.>> To put things in perspective for others, it's about 1 1/2 hours drive from > Buffalo, NY, and about 3 hours drive from Detroit, MI.________________________________________________________________________________Subject: Pietenpol-List: Re: N1929F Flight
