Pietenpol-List: Wing attach bolts - locking vs castle nuts
Subject: Pietenpol-List: Wing attach bolts - locking vs castle nuts
Re: Pietenpol-List: Wing attach bolts - locking vs castle nuts
I used castle nuts, partly for the reason you stated, and partly because my set up is very tight, and it is far easier to get them threaded and tightened.GaryNX308MBSent from my iPhoneOn Jul 29, 2013, at 11:57 AM, Greg Bacon wrote:> What kind of nut is recommended for the wing attach bolts? John Dilatush used nylon locking nuts on his wing attach bolts. What is the rule of thumb for using castle nuts vs lock nuts? My first thought was to use the castle nut - cotter pins in areas that are not easily viewed and/or where the nut would have a torque type force working on it.> > Thanks,> > -- > Greg Bacon> Prairie Home, MO> NX114D(Mountain Piet)> > > ============================================================================================================================================> ________________________________________________________________________________
RE: Pietenpol-List: Wing attach bolts - locking vs castle nuts
Greg,Castle nuts are preferred any where that rotation can be applied to thejoint (which should NOT be the case for the wing attach bolts). Nylonstopnuts should be fine, but I prefer to use the MS21042 all metal locknuts, primarily because they are lighter and smaller than standard AN 310castle nuts, but still develop the same load. They were standard hardwarefor all bolts on the F-16 program when I worked at General Dynamics manyyears ago. Castle nuts are fine if you have room to install the cotterpins.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Subject: Re: Pietenpol-List: Wing attach bolts - locking vs castle nuts
