Re: Pietenpol-List: A-65 and radio rfi..
Guys,I know this may have bed discussed, but I have two questions: 1) I will be using an A-65 on my SkyScout without electrical. It has Eisemann Am-4mags and non shielded harnesses. What have you done to suppress the rfi noise?2) I plan on using my iCom A-24 hand held radio and would like to put a groundplane behind the seat for a remote antenna. What antennas have you used?I have the same mags and harness in the Aeronca and the rfi is so bad, the radiois useless. Any suggestions welcomed. We have the VERY OLD STYLE PLUGS, do Ihave to use the newer shielded plugs and harness, or just the harness?Thanks,Ray KrauseSent from my iPad> On Nov 14, 2013, at 7:57 AM, "nightmare" wrote:> > This message cannot be displayed because of the way it is formatted. Ask thesender to send it again using a different format or email program. text/plain________________________________________________________________________________
RE: Pietenpol-List: A-65 and radio rfi..
Ray, My understanding is that you need the shielded harness AND plugs.That's what I have in my A65 and the radio is crystal clear. I have Slickmags and they came with the shielded harness, so I haven't tried it withoutshielding. Back when I owned a J-3 with an A65 (and Eismann mags) thehandheld radio had not been invented so there was no problem.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Original Posted By:> Ray Krause
Ray,Attached are pictures of the antenna/ground plane in my Grega, it workswell. In the seat back open picture the antenna is black and gp are green.I have one Eisemann Am-4 mag with shielded harness.Have you checked the AD on the Eisemann's?Skip> [Original Message]
RE: Pietenpol-List: Passenger Door Photos
It has been a little slow lately on the forum, and I know the recent cold snaphas slowed me as well as others down. With no heat in the workshop I had to movemy center section into the house to do some gluing (pictures to follow in anotherpost in a day or so). I don't think T88 likes 32 degrees in the shop!I thought I would post some photos of the passenger door recently welded into myfuselage by William Wynne and his outstanding welder, Vern Stephenson. The photosand comments are self-explanatory, but I thought it might help the builderscontemplating or building the steel tube fuselage.If you need any welding work done and you are anywhere near the Jacksonville FLarea, I would highly encourage you to contact William. Yes, he is The CorvairAuthority, and I am sure most of us think of him that way. However, he is alsoa highly skilled A&P with a place in his heart for Pietenpols and Pietenpolbuilders. He comes to Brodhead every year to talk Corvairs, but also talk Pietenpols.So, if you need help, give him a call.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: RE: Pietenpol-List: Passenger Door PhotosDate: Fri, 15 Nov 2013 08:10:17 -0700
Pietenpol-List: Re: A-65 and radio rfi..
Original Posted By: goffelectric(at)comcast.net
P.F. Beck made a very nice presentation at Broadhead in 2013 regarding making anantenna and ground plane for the Pietenpol. The ground plane needs to be equalin width and length to the height of your antenna.As for what to make the antenna from, he suggests finding some leftover weldingrod! He can be reached at the Barnwell regional airport in Barnwell SC. formore details barnwellairport(at)bellsouth.net--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 15 Nov 2013 17:05:52 +0000 (UTC)
Re: Pietenpol-List: New to the list
Subject: Re: Pietenpol-List: New to the list
Hello Keith,I live in Gilbert SC and about 75% done on my Piet. I would love to get togethersometime and share ideas. Please call me or email. 803-414-2235jack FasntaughtOn Nov 15, 2013, at 12:05 PM, goffelectric(at)comcast.net wrote:> ________________________________________________________________________________
Thanks, Jack. I am not sure how the Eisemann mags that I have accept the shieldedharness. With shielded plugs, are the shielded ignition wires grounded at theplug AND at the mag ends? The original Eisemann mags (AM-4) did not supportshielded plugs or wires, I think.Jack, do you just use the hand held's standard little antenna?Thanks,Ray KrauseSent from my iPad> On Nov 15, 2013, at 2:51 AM, "Jack Phillips" wrote:> > > Ray, My understanding is that you need the shielded harness AND plugs.> That's what I have in my A65 and the radio is crystal clear. I have Slick> mags and they came with the shielded harness, so I haven't tried it without> shielding. Back when I owned a J-3 with an A65 (and Eismann mags) the> handheld radio had not been invented so there was no problem.> > Jack Phillips> NX899JP> Smith Mountain Lake, Virginia> > -----Original Message-----
Original Posted By:>> Ray Krause
Skip,Yes, I have conformed to the AD, no problem with the coils on the mags. Do youalso run shielded plugs? Where did you get the shielded harness, make it? Andif so, how did you make it?On the antenna: the coax cable central wire connects to the antenna which is 23"long, and the ground wire connects to each of the 23" ground pieces? The groundpieces are then attached to the fuselage sides vertically and the antennais held horizontally, or parallel to the longerons? And these measurements workwell for communications frequencies?Thanks, this really helps, just what I needed for the antenna.Looking forward to your response. Way too many questions?!Thanks,Ray KrauseSent from my iPad> On Nov 15, 2013, at 4:29 AM, "skipgadd(at)earthlink.net" wrote:> > Ray,> Attached are pictures of the antenna/ground plane in my Grega, it works> well. In the seat back open picture the antenna is black and gp are green.> I have one Eisemann Am-4 mag with shielded harness.> Have you checked the AD on the Eisemann's?> Skip> > >> [Original Message]
RE: Pietenpol-List: Radio Noise--- Tony Bingelis 1995 answers to your
Just between you and I, Ray, I don't have Uncle Tony's books. Don't tellMike, though...I'm not sure that he wouldn't just snap!Gary BootheNX308MB-----Original Message-----
Pietenpol-List: Re: New to the list
The pictures that are attached to this post are pictures I took of Keith's Pietenpolproject that he brought to this past weekend's Corvair College #27 in Barnwell.As you can see, he does nice work. Far better than mine, that is for sure.He told me that he had been "lurking" on the Forum for a while. I told him withnice work like this, he needs to post and be an active part of the forum.As you can see, Keith does nice work (other than stealing his children's bicyclerims [Laughing] ).Welcome to the ACTIVE forum, Keith.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ______Date: Sat, 16 Nov 2013 01:23:42 +0000 (UTC)
Re: Pietenpol-List: Re: A-65 and radio rfi..
Thanks, Mike. I will look into this, seems like an easy answer.Ray KrauseSkyScoutSent from my iPad> On Nov 15, 2013, at 9:39 AM, Michael Perez wrote:> > > Maybe:> > http://www.aircraftspruce.com/catalog/a ... key=216737> > If God is your co-pilot...switch seats.> Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > > > > ________________________________________________________________________________
Re: Pietenpol-List: Radio Noise--- Tony Bingelis 1995 answers to your
Gary,Now I have dome information I can use against you in the future! I have the completeset, but forget to use them until someone points out my mistake! Some ofhis stuff is repetitive and/or self evident. Good stuff, just the same.Flying this weekend?RaySent from my iPad> On Nov 15, 2013, at 3:52 PM, "Gary Boothe" wrote:> > > Just between you and I, Ray, I don't have Uncle Tony's books. Don't tell> Mike, though...I'm not sure that he wouldn't just snap!> > Gary Boothe> NX308MB> > > -----Original Message-----
Thanks, Bob. I wrote to him and requested any info he might be able to supply.Thanks,Ray KrauseSent from my iPad> On Nov 15, 2013, at 8:05 AM, "bdewenter" wrote:> > > P.F. Beck made a very nice presentation at Broadhead in 2013 regarding makingan antenna and ground plane for the Pietenpol. The ground plane needs to beequal in width and length to the height of your antenna.> > As for what to make the antenna from, he suggests finding some leftover weldingrod! He can be reached at the Barnwell regional airport in Barnwell SC. formore details barnwellairport(at)bellsouth.net> > --------> Bob 'Early Builder' Dewenter> Dayton OH> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 148#413148> > > > > > > > > > ________________________________________________________________________________
I'll fly in the morning, if the wind dies down. It's "Airport Day" at LHMand avgas is a mere $4.98!! Come on down....!Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Re: Radio Noise--- Tony Bingelis 1995 answers to
Subject: Re: Pietenpol-List: Re: Radio Noise--- Tony Bingelis 1995 answers to your questions
Ray,Yes, that is how the wires connect. I think you must be seeing the elevatorconnecting rod as the antenna. The antenna is vertical against the fuzeside. I wanted the antenna vertical and put the ground planes where theywould fit. Yes, the 23" length works well for the middle of the comfrequencies.I bought the plane with 2 non impulse Bendix(lunchbox) mags. I got theEisemann on ebay, so it would be safer to hand prop, and a guy on the fieldgave me the shielded harness, he had an incomplete set of 7 and I onlyneeded 4. They aren't really made to fit the Eisemann, I got some of thoseauto type rubber booties and just stuck the leads in the Eisemann and theyhave been good for about 200 hours now. Yes, I am running the same standardaircraft shielded plugs that came with the plane, used with the Bendix mags.Skip > [Original Message]
Re: Pietenpol-List: Rick's flight
........kind of looks black and yellow...........Dan HelsperPuryear, TN-----Original Message-----
RE: Pietenpol-List: Re: Radio Noise--- Tony Bingelis 1995 answers to your
OK, ALREADY!! They are officially on the Christmas Wish List!!Gary BootheNX308MB-----Original Message-----
Gary,Sorry I missed you today, spent too much time in Oroville. It was EAA breakfastday. Is "AIRPORT DAY" every third Saturday? Sure was a nice day to fly. Hopeyou got up. I managed to get in 1.1 hrs.Thanks,RaySent from my iPad> On Nov 15, 2013, at 9:33 PM, "Gary Boothe" wrote:> > > I'll fly in the morning, if the wind dies down. It's "Airport Day" at LHM> and avgas is a mere $4.98!! Come on down....!> > Gary Boothe> NX308MB> > > -----Original Message-----
Attached is a photo of the setup that I have in Scout. Corky used a piece of shopscrap aluminum to form the ground plane, and the ELT antenna and VHF COM antennashare the ground plane. The ELT is also mounted to the aluminum, sinceit is nicely accessible for inspection and service behind the seat in that locationand it is pretty likely to survive a crash there as well. A short pieceof coax leads from the COM antenna (a standard aircraft bent stainless steelwhip) to a bulkhead fitting right above the pilot's right shoulder, where a shortcoax lead can be connected to a handheld when it's in use. The rest of thetime there are no wires visible in the cockpit and the bulkhead fitting hasa screw cap to cover it. The black thing at the bottom of the photo is a smallpouch that is attached to the back of the hinged rear seatback/access panel.Yes, I know that there are aircraft cables in close proximity to the ELT and COMantennas and that they mess up the nice radiation patterns. Yes, I know thatthe ground plane is dimensioned less than ideally for optimum antenna efficiency.Yes, I know that the antennae are too close to each other and neither isoptimally placed on the ground plane. Yes, I know that there are signal lossesthrough the additional BNC connectors and coax. I can live with that.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/grou ... ______Date: Sat, 16 Nov 2013 19:42:21 -0800
> Subject: Re: Pietenpol-List: A-65 and radio rfi..>>> Guys,>> I know this may have bed discussed, but I have two questions: >> 1) I will be using an A-65 on my SkyScout without electrical. It hasEisemann Am-4 mags and non shielded harnesses. What have you done tosuppress the rfi noise?>> 2) I plan on using my iCom A-24 hand held radio and would like to put aground plane behind the seat for a remote antenna. What antennas have youused?>> I have the same mags and harness in the Aeronca and the rfi is so bad,the radio is useless. Any suggestions welcomed. We have the VERY OLD STYLEPLUGS, do I have to use the newer shielded plugs and harness, or just theharness?>> Thanks,>> Ray Krause>>> Sent from my iPad>> > On Nov 14, 2013, at 7:57 AM, "nightmare" wrote:> > > > This message cannot be displayed because of the way it is formatted.Ask the sender to send it again using a different format or email program.text/plain>>________________________________________________________________________________Subject: Pietenpol-List: Passenger Door Photos
>> Subject: Re: Pietenpol-List: A-65 and radio rfi..>> > >> >> Guys,>> >> I know this may have bed discussed, but I have two questions: >> >> 1) I will be using an A-65 on my SkyScout without electrical. It has> Eisemann Am-4 mags and non shielded harnesses. What have you done to> suppress the rfi noise?>> >> 2) I plan on using my iCom A-24 hand held radio and would like to put a> ground plane behind the seat for a remote antenna. What antennas have you> used?>> >> I have the same mags and harness in the Aeronca and the rfi is so bad,> the radio is useless. Any suggestions welcomed. We have the VERY OLD STYLE> PLUGS, do I have to use the newer shielded plugs and harness, or just the> harness?>> >> Thanks,>> >> Ray Krause>> >> >> Sent from my iPad>> >>> On Nov 14, 2013, at 7:57 AM, "nightmare" > wrote:>>> >>> This message cannot be displayed because of the way it is formatted.> Ask the sender to send it again using a different format or email program.> text/plain> > > ________________________________________________________________________________
Original Posted By:> >> Ray Krause
> Subject: Re: Pietenpol-List: A-65 and radio rfi..>>> Skip,>> Yes, I have conformed to the AD, no problem with the coils on the mags.Do you also run shielded plugs? Where did you get the shielded harness,make it? And if so, how did you make it?>> On the antenna: the coax cable central wire connects to the antenna whichis 23" long, and the ground wire connects to each of the 23" ground pieces?The ground pieces are then attached to the fuselage sides vertically andthe antenna is held horizontally, or parallel to the longerons? And thesemeasurements work well for communications frequencies?>> Thanks, this really helps, just what I needed for the antenna.>> Looking forward to your response. Way too many questions?!>> Thanks,>> Ray Krause>> Sent from my iPad>> > On Nov 15, 2013, at 4:29 AM, "skipgadd(at)earthlink.net" wrote:> > > > Ray,> > Attached are pictures of the antenna/ground plane in my Grega, it works> > well. In the seat back open picture the antenna is black and gp aregreen.> > I have one Eisemann Am-4 mag with shielded harness.> > Have you checked the AD on the Eisemann's?> > Skip> > > > > >> [Original Message]
