Pietenpol-List: Re: best primer for 4130 fuselage
Original Posted By: "Pietflyer1977"
Again, the main problem with most of these newer glues is that they've never been evaluated for aviation purposes. I use Titebond 3 (the nearly waterproof formulation) to glue up longbow laminations, a use that subjects the glue line to incredible compression/tension forces & have not had one come apart yet, so I'm willing to bet it's structurally strong enough for many aircraft uses, but that doesn't mean I'd use it on an aircraft without some serious testing in that application.Kip GardnerOn Nov 30, 2013, at 3:51 PM, tools wrote:>> Not trying to start something, but along the idea of testing your > own...>> Is there any reason yellow glue isn't acceptable? I've built LOTS > of furniture with it that has seen LOTS of conditions. Indoor > stuff, outdoor stuff, stuff in the sun, stuff on trucks subject to > vibration, stuff I load the ever living daylights out of (benches > and such) and have never had a glue joint fail that was properly > built and glued up. Titebond II even has lots of water proofness.>> Not really knowing the answer to that myself, I'm not necessarily > planning to use it, but i have always wondered.>> I have recently found lots of great information from the boat guys > on using epoxy that I really like. Boat hulls certainly see > conditions rougher than I'll ever put an airplane through. I'm > planning on using T88 (and am using it for some comprehensive > repairs - longeron scarfing, tail post replacement, etc) but am > considering using some West System stuff.>> Food for thought.>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: best primer for 4130 fuselage
Re: Pietenpol-List: Re: best primer for 4130 fuselage
Original Posted By: Glen Schweizer
