Crandall - you need to unsubscribe using the matronics link at the bottom ofthe page.Gary BootheNX308MB
Pietenpol-List: "Unsubscribing"
Pietenpol-List: Re: fuselage side
Original Posted By: "Braniff1966"
We have always glued the fuselage sides up in the same jig. No gussets. Then sandthem on both sides with a big flat sanding block, like a 1x4, to clean andtrue up everything. At that point make a left and right side by adding gussetsand side sheeting. It's worked four times. :DRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: fuselage side
do like the guys say...install gussets at major points. t88 is a great glue.hydeRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: fuselage side
Did mine the same way as DennisGlued up both sides and added gussets after they were out of the jigDidn't have any problem with the joints popping (T88)--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 10 Dec 2013 08:23:37 -0600 (GMT-06:00)
