Pietenpol-List: leading edges
Thanks all for the input.One more question. The plans show leading edge material only on the top,has anyone wrapped it around the underside also? Would there be any benifitto this?Dick Navratil________________________________________________________________________________
Re: Pietenpol-List: leading edges
Subject: Re: Pietenpol-List: leading ddgesIn a message dated 12/11/00 11:23:50 PM Central Standard Time, rambog(at)erols.com writes: >>Gene, Yes, that was Doug Bryant and myself !! I believe there were a couple of Travel Air drivers, that were building Pietenpols. Is your's the one that is blue over silver fuse, with silver wings? NC8853? What a beautiful airplane ! The one I saw in the hanger that evening, with the wrinkles on top of the bottom of the wing, was behind your plane, off to the left. It appeared to have a 'V' type trailing edge. It would make sense, that the trailing egde moved forward, when the fabric was tightened. Except for a few wrinkles, it was yet another beautiful Travel Air. Please let all the Travel Air folks know that their arrival here, was much appreciated by a great number of people !! Keep 'em Flyin' !!!!Chuck G.________________________________________________________________________________Date: Tue, 12 Dec 2000 13:48:53 -0600Subject: Re: Pietenpol-List: leading edges
Original Posted By: jefay(at)juno.com
Original Posted By: Chris Tracy
I like the idea of wrapping around the leading edge to 3" on the bottom sideand to the spar on top. I was looking at rolls of aluminum in ACS, not wideenough. I am going to check out the rools of aluminum roof flashing stock ahome building store. It comes in a variety of widths. I don't know aboutthickness yet. Something .016 to .020 would be good.Dick Navratil________________________________________________________________________________Date: Tue, 12 Dec 2000 17:17:27 -0800Subject: Re: Pietenpol-List: leading edges
Original Posted By: "Mike Bell"
Subject: Re: Pietenpol-List: leading edgesI just don't see any advantage at all, of extending the plywood around the tight radius of the leading edge, and extending it under the wing. The disadvantages would be weight, extra work, and expense. When my plans built, one piece wing was complete, with paint, it would easily twist 4 or 5 inches. The 1/16" plywood, as opposed to 1/32" plywood, offers better rigidity for cleaning the wing, and protection against bird strikes...on the other hand they say Pietenpols take bird strikes from the rear !! Aluminum has a different expansion rate than wood, and I'm sure, over time, would loosen up the nails, especially on a one piece wing. Most aircraft aluminum is 2024 (copper alloy for strength, but corrodes more readily). Any flashing type aluminum is 1100 (soft, malleable, and very corrosion resistant). Some designs use a 'D' box in front of the front spar, but the aft edges of the plywood is glued to the top and bottom of the front spar, to help check torsional load. On a Pietenpol, the two lift struts do that. In other words...Follow the Plans, and you can't go wrong !!Chuck Gantzer________________________________________________________________________________Subject: Re: Pietenpol-List: leading edges
owner-pietenpol-list-server@mat Pietenpol-List:
08:09:19 AMI have some flashing on the shelf in my workroom. I think that it's"dead soft" aluminum. I had assumed (we all know where that can getyou) that being this soft would not be good for the leading edge as itis not right for the cowling either.Mike BellColumbia, SC "Richard Navratil" To: Sent by: cc: owner-pietenpol-list-server@mat Subject: Pietenpol-List:leading edges ronics.com 12/12/2000 06:25 PM Please respond to pietenpol-list I like the idea of wrapping around the leading edge to 3" on thebottom sideand to the spar on top. I was looking at rolls of aluminum in ACS,not wideenough. I am going to check out the rools of aluminum roof flashingstock ahome building store. It comes in a variety of widths. I don't knowaboutthickness yet. Something .016 to .020 would be good.Dick Navratil________________________________________________________________________________Date: Wed, 13 Dec 2000 09:09:45 -0500
I understand, and the plans suggest , that the original Piet's leading edgewas made with Quaker Oats' boxes glued to the leading edge and varnished.Is this right guys?walt---------------------------------------------------------- Original Message -----
Original Posted By: javier cruz
RE: Pietenpol-List: help piets
Javier,,,, You can get manuals, part catalogs, and just about anything you need from Clark's Corvair, 400 Mohawk Trail, Shelburne Falls, Mass. 01370the phone number is 413 625 9776 website is www.corvair.com.For the serial number, I used the number assigned to my plans fromDon Pietenpol. If your converting a corvair,,, William Wynne is a really good source for info on how to do it right. His website ishttp://www.flycorvair.com/..Hope this helps,,Carl-----Original Message-----
Original Posted By: Leo Powning
Re: Pietenpol-List: help piets
Original Posted By: Don Mosher
Subject: Re: Pietenpol-List: leading edges>>Walt,> I don't know for sure what BHP used but the original plans call for>using cardboard as one of the possibilities.A Piet built by the Broadhead people a few years back used cardboard leadingedge. I believe that was the one with the round engine.Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________Date: Sat, 16 Dec 2000 01:54:45 -0600
By the way, it is an AD to replace those cardboard gusstes on Aeronca wings!----- Original Message -----
Subject: Re: Pietenpol-List: Bushing Stock ???????Thanks Doug, I'll give it another try tomorrow as I have 3/8 bushing stock out the uhulos.Corky in La. It's still getting colder with no electricity.________________________________________________________________________________Date: Sat, 16 Dec 2000 19:08:11 -0600Subject: Re: Pietenpol-List: leading edges
RE: Pietenpol-List: leading edges
Original Posted By: raymond smith [mailto:badge784k(at)yahoo.com]
Mike,Keep working on the scarfer. Sandpaper like Vic's may get loaded up quicklywith cardboard, you may have to use a knife or chisel ;)Skip-----Original Message-----
Pietenpol-List: Re: leading edges
Bill; I stand corrected. You are absolutely right... the A80 is the slug, notthe C85.Carry on!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: leading edges
Re: Pietenpol-List: Re: leading edges
Original Posted By: Crandall Eldredge
Plywood leading edges will certainly provide more wing stiffness than the flattenedoatmeal containers that Mr. Pietenpol is said to have used to shape the leadingedges originally.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 14 Dec 2013 10:41:49 -0700Subject: Re: Pietenpol-List: Re: leading edges
Original Posted By: Peter Johnson
Just sent my daughter a copy of the address. She was wondering what she couldget me for Christmas. Do you think I was being too pushy? Ha Ha.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 15 Dec 2013 09:51:17 +1100Subject: Re: Pietenpol-List: leading edges
Original Posted By: "Braniff1966"
...in anycase, it sold fast today. Had an engine mount, everything..even the bafflingwas still attached...they were asking $4400. Don't know if the buyer low-balledthe price or not, but he got a good deal. I went there today. I was contemplatingbuying it, but it was too late. I didn't need an engine, but C85'sare in demand, too good to pass up.--------KLNCA65-8N2308CAN HardwareAirframe 724TTW72CK-42 SensenichStandard Factory GN-1Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: leading edges
RE: Pietenpol-List: Re: leading edges
There are various ways. The attached photo shows the leading edge piece thatI used. It also has a dado that receives the plywood.Gary BootheNX308MB-----Original Message-----
Keith, You are reading the plans correctly, ply only on top. Just run the ply down theLE a half inch or so and feather to blend in like you said. That is probablywhat I will do as my LE is already attached and it doesn't have dado cut out.Skip----- Original Message -----
echobravo4 wrote:> Hey Grant-> I believe the placement of the flop is shown in the 1932 flying and glider plans> But I don't think there are any details on how you build it.> Seems like it would be similar to making the aileronsI just improvised my hybrid flop. Makes it a lot easier getting in an out.--------Rick HollandNX6819ZRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ______Date: Sun, 15 Dec 2013 20:12:02 -0700Subject: Re: Pietenpol-List: Re: leading edges
> * *Pietenpol-List: Re: leading edges
